PA Case Sensitive vs. TM1 10.2 not case sensitive
jcr55
Version: 9.5.2 FP2
Excel Version: Excel 2007
Post by jcr55 »
Current TM1 version: 10.2.2 FP7
We are very close to starting the switch to IBM Planning Analytics Local 2.0.6.
I read somewhere that PA will treat upper and lower case as different values (i.e. it will be case sensitive), versus TM1 historically has been not case sensitive.
I inherited many (61, to be exact) TI processes where a Variable name has an upper case "I" in one command, and a lower case "i" in another command - example:
strWIld = '*.txt';
strName = 'FlashData' | strWild;
In TM1 10.2.2, the TI processes run correctly.
Will they have a problem in PA 2.0.6 thinking they are now two different variable names?
Re: PA Case Sensitive vs. TM1 10.2 not case sensitive
Just double checked
a=2;
b=a*A;
compiles just fine (in old style TI editor)
but
a=2;
b=a*c;
does not so I don't believe there is an issue
The only place I have noticed case being issue is in the server name, not noticed an issue elsewhere, not even sure it is always an issue with the server name. Might have been a defect that existed for a while.
I think they mean PA is case sensitive for TM1 objects like cubes, dimensions, elements, attributes, etc. Not variable names inside a TI process.
jim wood
Version: PA 2.0.7
Post by jim wood »
tomok wrote: Thu Nov 01, 2018 4:23 pm I think they mean PA is case sensitive for TM1 objects like cubes, dimensions, elements, attributes, etc. Not variable names inside a TI process.
Oh yah, copy and paste ahoy!!
Shop at Amazon
jcr55
Version: 9.5.2 FP2
Post by jcr55 »
OK, great. Thank you to all who responded.
If (more likely when) case sensitivity is introduced I think it is a very safe bet that this will be controlled by a tm1s.cfg parameter where the default value is set to false for backwards compatibility.
jim wood
Version: PA 2.0.7
Post by jim wood »
lotsaram wrote: Thu Nov 01, 2018 5:50 pm If (more likely when) case sensitivity is introduced I think it is a very safe bet that this will be controlled by a tm1s.cfg parameter where the default value is set to false for backwards compatibility.
We all know how well these things have worked in the past......
Shop at Amazon
