In Planning Analytics Local v2.0.5 environment, I created a cube with 27 dimensions and it displays #N/A as value in consolidated cells although there is no rule in the cube at all.
Did you face this issue before? Any comments will be appreciated.
TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
- mce
- Version: Planning Analytics Local 2.0.x
- Excel Version: 2013 2016
Re: TM1 DISPLAYS #N/A VALUES INSTEAD OF "0"
Restarting Architect solves the issue.
- Steve Rowe
27 dimensions !
Are you sure?
Are you sure?
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
That can be the case when you are stuck in batch update mode, for example a TI that you run switches it on on the Prolog but then aborts without switching it off on the epilogRestarting Architect solves the issue.
