Determine whether a TI process exists
Hello all,
Quick question. In Turbo Integrator, we have CubeExists(), DimensionExists(), ViewExists(), SubsetExists().
Why not ProcessExists()? Although Dimix() will do as well, why not have a direct function?
Wim
Re: Determine whether a TI process exists
Wim Gielis wrote: Quick question. In Turbo Integrator, we have CubeExists(), DimensionExists(), ViewExists(), SubsetExists().
That's a very good point; and also ProcessExists is the one which is actually needed more than most of the others since a process is the only TM1 object that I can think of which can be in one of three, not two, states. (Does not exist, exists but has compile errors, exists without compile errors. With every other type of object it either is or it ain't.) If you are trying to call another process, you certainly want to know which one of those three it is.
Yes, IMHO that one should certainly be introduced as a function which can return one of three, not two, values.
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
Cube rules have the same set of characteristics and states. Similar functions for rules would probably be useful too. What would really do it for me though would be ProcessLoadFromFile. That would be sweet.
Duncan P wrote:Cube rules have the same set of characteristics and states.
Quite so. I qualify my previous statement accordingly.
Duncan P wrote: Similar functions for rules would probably be useful too. What would really do it for me though would be ProcessLoadFromFile. That would be sweet.
It would indeed; it would be a dead easy way to do hot promotion. I suspect that Iboglix might argue, and not without some justification, that there would be a risk of loading corrupt code with such a function had the .pro file been manually monkeyed with rather than being created by the Editorsaurus or Muddler in a dev environment, but really that's no different to the current situation where .pro files can be put in a data directory to be loaded on restart. Overall I think that the advantages of your idea hugely outweigh any potential risks.
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Post by TrevorGoss »
Hello Wim.
I know this is an old thread but I have a possible solution to your question.
You can find out if a process exists in a given server, by searching through the flat files of that server.
You use the WildCardFileSearch function and direct it at the data files of the relevant server.
My code below is a quick demo:
vName = 'NameOfDesiredProcess';
Z = Relevant Drive
vWild =WildCardFileSearch('Z:\RelevantService\DataFilesOfService\' | vName |'.pro','');
ASCIIOUTPUT('Z:\YourChosenFile\vWild.txt',vWild);
the vName variable is given a process name, you then pass that variable through the WildCardFileSearch function, then you run the process.
You do not need an ASCIIOUTPUT, you can use the return value any way you like.
TrevorGoss wrote:Hello Wim.
Z = Relevant Drive
Trevor,
As wim eluded to in his first post the easiest way to do this is a dimix on the }processes dimension, your code would also work but if I was to query the data directory I would use fileexists () as opposed to the wildcard function.
The point was just why on earth they put in CubeExists or DimensionExists and not ProcessExists functions.
TrevorGoss
Version: 10.2.1.1
Declanr,
I agree, we have 3 different ways of doing it here, so a function called ProcessExists should be straight forward.
Thanks for your response.
Follow up:
ProcessExists
has been added recently to the TI functions.
Thank you IBM.
tm123
OLAP Product: tm1, cognos bi
Post by tm123 »
Wim Gielis wrote: Mon Feb 26, 2018 11:37 am Follow up:
ProcessExists
Thank you IBM.
It would be nice if they also added a TI Function to delete a TI Process (such as ProcessDestroy or ProcessDelete). I have some TI Processes that their names start with } (like control objects) and they cannot be deleted from Server Explorer so the only way is to delete the .pro file from Data folder
tm123 wrote: Wed May 02, 2018 1:32 pm
ProcessExists
Thank you IBM.
Did you check AsciiDelete ? You will still have to bounce the server but at least deleting the pro file can be done with a process.
Or use the TM1 REST API to delete a process.
