Element Security Override
tm1green
Post by tm1green »
Guys,
I have element security set up for the department dimension. However, I do not want the element security to apply when the department dimension is used in some cubes. How do I go about setting this up?
Thanks in advance.
Re: Element Security Override
In my humble the easiest way of doing this is to use a clone of the dimension in the other cubes. There are processes in the Bedrock library which can handle the cloning (including attributes) and which can be scheduled as chores.
Another option is to create a CellSecurity cube for those cubes that use the department dimension differently and apply your security there.
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
Alan Kirk wrote: ↑Thu Oct 25, 2018 10:35 am In my humble the easiest way of doing this is to use a clone of the dimension in the other cubes. There are processes in the Bedrock library which can handle the cloning (including attributes) and which can be scheduled as chores.
What about Data Reservations? They seem simple enough to apply and manage, although I would only use them to temporarily apply security. In the OP's case, I'd go with separate dimensions or hierarchies (PA).
Just curious as to thoughts on Data Reservations.
Ty
Cleveland, TN
tm1green
Post by tm1green »
Thanks guys. I settled with some rules in the element security control cube.
