returnviewhandle
Moh
OLAP Product: Cognos
Version: 10.1.1
returnviewhandle
Post by Moh »
Good morning sir,what use of RETURNVIEWHANDLE what actually it do.pls give example
daniel.havassy
OLAP Product: Planning Analytics Local
Version: 2.0.4
Re: returnviewhandle
Post by daniel.havassy »
One area where you'd encounter it is drill-through to a TM1 cube view. The drill TI process would have that as a statement in Prolog. If you are new to drill-throughs, check the product documentation of Planning Analytics, you'll find good explanations there.
daniel.havassy wrote: Mon Oct 08, 2018 7:28 am One area where you'd encounter it is drill-through to a TM1 cube view. The drill TI process would have that as a statement in Epilog.
daniel.havassy wrote: Mon Oct 08, 2018 7:28 amIf you are new to drill-throughs, check the product documentation of Planning Analytics, you'll find good explanations there.
Emphasis added.
I happen to be working on drill through to cube views the last 2 days. I don’t find the documentation good in this topic.
daniel.havassy
Version: 2.0.4
Valid point Wim, I guess I shouldn't have used the word "good" or "explanation" :?
