Tm1 Support with Cumulative Data
Sergio85
OLAP Product: Planning Analytics 2.0
Version: TM1 64bit
Excel Version: Excel 2013
Post by Sergio85 »
Relatively new user to Tm1 and I need advise on setting up a cube to cumulate data based on the dimension set up that is pre-existing that I cannot change.
There is already a pre existing formula created that pulls data for the 'Monthly FY Total Data' (by month) consolidation based on data inputs from two other cubes. I am trying to create a formula that would be unique to the 'Monthly Cuml' consolidation that will calculate data by month (at an element level) based on the elements from the 'Monthly FY Total' consolidation. I have tried to create a rule based off of attributes to pull data to take 'Previous Month' and add it to 'Current Month' in order to derive to a total, respectively, with no success.
Here are the current rules created concerning the Monthly Cuml consolidtation
['Cuml Oct']=N: ['Oct']; (which works with no problem, I just do not want add a similar formula 11 more times)
[{'Cuml Nov','Cuml Dec', 'Cuml Jan', 'Cuml Feb'}]=N:DB('Cube Data',!Versions,
!Fys,!Job Type,!Payscale,!Amount,!Programs,ATTRS('Cumulative Data',!Cumulative Data, 'Current Month')) +
!Fys,!Job Type,!Payscale,!Amount,!Programs,ATTRS('Cumulative Data',!Cumulative Data, 'Previous Month'));
Essentially, I am hoping to create on rule that will calculate the cumulative data as oppose to creating 12 different formulas.
Please see the attachment I have added to this thread to give a better visual representation on what I am trying to calculate.
Everything that is colored in blue-gray is considered a dimension and I am trying to create a formula to solve for yellow/gold.
I also displayed the attributes editor
(**the 'Monthly Cuml' consolidation goes throughout the FY and does not stop at 'APR Cuml')
Thanks in advance!
Tm1 Forum Support.xlsx
(15.25 KiB) Downloaded 576 times
jim wood
Version: PA 2.0.7
Re: Tm1 Support with Cumulative Data
Post by jim wood »
Moved to the forum. Can you please only post a topic once. All duplicates will be removed.
You should be doing this in the consolidations for the dimension not the rules, rules will be significantly slower to calculate than a consolidation and will also require more feeding.
You might want to put a picture, instead or as well as the .xlsx as many people won't be able to download it to look at.
Sergio85
Version: TM1 64bit
Post by Sergio85 »
Tm1 Support.JPG (204.04 KiB) Viewed 4816 times
Adding Screen shot for further review
