Hierarchy Changes affecting BI reports
Reuben
Post by Reuben »
Hello Gurus,
Sorry if question this has been asked earlier.
I have created several reports using Report Studio which works fine until the hierarchy changes in TM1.
Once that happens the reports break (meaning they don't pick up the element(s) that has changed).
Removing and adding back has been the only option for me.
However, I noticed one change in the MUN (Member Unique Name) that is different.
When I originally created the report the MUN was created differently for example
[5YR Actual Comparison].[Location].[Location]->:[TM].[Location].[Location].[@MEMBER].[881]
whereas the newly added elements MUN looks like this
[5YR Actual Comparison].[Location].[Location]->:[TM].[Location].[Location].[@MEMBER].[OPERATIONS DIVISION^885]
The newly added element include the hierarchy (OPERATIONS DIVISION), this is what is causing the reports to break.
Is there a way I to add the element into Report Studio without including the hierarchy?
Also, when I originally created the report why did it not include the hierarchy (which is good)
Thanks in advance guys.
tm123
OLAP Product: tm1, cognos bi
Re: Hierarchy Changes affecting BI reports
Post by tm123 »
You need to execute RefreshMdxHierarchy after the Dimension Hierarchy changes.
Reuben
Post by Reuben »
ok thanks. Let me take a look
venkat
OLAP Product: Cognos
Version: Cognos TM1 10.0.1
Excel Version: Excel 2007
Post by venkat »
HI Reuben,
Is it efreshMdxHierarchy(''); function working for you ?
Today i also faced same issue i am getting error like attached screen shot , Could you please reply .
Tm1
