TM1 applications not available in Cognos Analytics
Paul-TM1
Post by Paul-TM1 »
I have installed Planning analytics 2.0.4 and found that TM1 applications not available in Cognos Analytics.
Earlier, whenever I installed, TM1, applications were available by default in Cognos BI soon after the TM1 application server is started.
Can someone tell me what could have gone wrong?
CA version:11.0.9
TM1 Server installed on: Windows 2012 R2.
CA Server installed on: Windows 2016
Please let me know if more details are required.
Luther.
Paul-TM1
Re: TM1 applications not available in Cognos Analytics
Post by Paul-TM1 »
I see that many people have seen it, but have not answered. Thought it's good to add a picture for reference t oexplain.
The missing folder is 'IBM Cognos TM1 Applications - My Applications' .
Paul.
CA-TM1 Applications are Not visible-2.png (50.3 KiB) Viewed 4130 times
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
The "Applications" folder name is set in pmpsvc_config.xml file (<tm1 install>/webapps/pmpsvc/WEB-INF/configuration/). Is it correct here?
Is it a completely new blank server, or you have migrated from another instance? If so, from which version? Did you migrate Content Store database?
Try to create new application. Will the Apps folder be created in CA?
