Hi Gurus,
I have created a TM1 application that opens up in Contributor. The application is of type - 'Central' with no Approval Hierarchy and no Control dimension. This is to set attributes on the main hierarchy that is used in other TM1 applications as approval hierarchy. Since this is a simple one which is to be accessed by a few, no security was set on it with a few who users who can access the package can edit.
Now the issue is, when it's opened as a user, the cells are grayed out. How do we take off the cell locks giving access to users? Like I said, this dimension in the cube used is the approval hierarchy in another application.
Any help is greatly appreciated. I have developed and was about to roll out to users and found the error.
We use 10.2.2 FP7.
Paul.
Security on a TM1 Contributor Application
Re: Security on a TM1 Contributor Application
Thanks folks. I found the issue. I did not give Write access on the cube. It's all set to work.
Paul.
Paul.
