Add attributes to control dimension
Paul-TM1
Post by Paul-TM1 »
How do we add attributes to a control dimension? I remember to have done it once and it's not working now. Is there a special way to add for control objects?
Paul.
Re: Add attributes to control dimension
A small Turbo Integrator process ?
Paul-TM1
Post by Paul-TM1 »
Thanks Wim Gielis.
I want to create a pick list on a control dimension from values in a dimension. Sorry. I should have been clear.
I tried things like below and both don't seem to work.
dimension:dimension_name
subset:dimension_name:subset_name
Paul.
If the dimension is used in a cube, have you tried creating a picklist cube then writing the relevant rule against the dimension?
BR, George.
I seem to recall that in certain versions you needed a picklist cube to be able to add picklists to control dimensions but in other versions you could do it by a picklist attribute. Im not sure which versions it is as for certainty i always use a picklist cube now.
Paul-TM1 wrote: Sun Apr 29, 2018 5:51 pm Thanks Wim Gielis.
Paul.
There is a big difference between creating an attribute and a picklist. In fact the two are nothing alike at all.
Declan is correct. For picklists to work in control cubes you must have a picklist cube. This is true for all versions.
There was definitely a version where you could use a normal picklist attribute but if I remember correctly it was something like 10.1 and it was something that hadn't been possible before and then in a later version got removed again, it caused problems with an upgrade I did where the functionality disappeared.
Paul-TM1
Post by Paul-TM1 »
Thanks for all the advises. I will try a pick list cube.
Paul.
Paul-TM1
Post by Paul-TM1 »
One last question. In the rule of pick List Cube, when I tried to add from a dimension, it does not work.
['AcqType'] =S: 'dimension::Attribute-AcqType-All' ;
Static values work.
Can somone help me with this bit of code?
thanks,
Paul.
Can you describe in words where the picklist values should come from ?
A guess: if Attribute-AcqType-All is a dimension name, then replace :: with :
