I have just stood up a new instance of PA2.0 and TM1top is not working. I have gathered the files like in 10.2.2 into a folder and it gives an error.
Could not connect to server "sdata" on admin host "--ADMIN_HOST--"
Press "R" to retry, any other key to exit
I have attached a pic that the list of files in the folder. Are there any extra files that have to be added to the folder? Can someone help?
Also, when I change the default tm1top.ini file, it says "Please check if this file is opened in another program".
Thanks in advance.
Paul.
TM1TOP not working - Planning Analytics -2.0
Paul-TM1
- TM1Top-Files.PNG (54.86 KiB) Viewed 3966 times
Re: TM1TOP not working - Planning Analytics -2.0
Must admit I’ve not used tm1 top in a while but if you’ve copied from an old version I would guess that your ssl certs could be out of sync.
Paul-TM1
Thanks Declnar.
All files including SSL certs are from PA2.0 and not from TM110.2.
Paul.
Paul.
- macsir
- Version: PAL 2.0.9
You missed some files and directories for PA2.
1. C directory
2. gsk8valn_64.dll
3. gsk8dbfl_64.dll
4. gsk8kicc_64.dll
If you get the copy from installation folder, it should run fine.
1. C directory
2. gsk8valn_64.dll
3. gsk8dbfl_64.dll
4. gsk8kicc_64.dll
Paul-TM1
Thanks macsir.
Figured it out. Here is a full list.
C
N
ssl
gsk8acmeidup_64.dll
gsk8cms_64.dll
gsk8dbfl_64.dll
gsk8drld_64.dll
gsk8iccs_64.dll
gsk8kicc_64.dll
gsk8km_64.dll
gsk8ldap_64.dll
gsk8msca_64.dll
gsk8mscng_64.dll
gsk8p11d_64.dll
gsk8p11_64.dll
gsk8ssl_64.dll
gsk8sys_64.dll
gsk8valn_64.dll
log4cxx.dll
log4cxxw.dll
msvcp100.dll
msvcr100.dll
tm1api.dll
tm1top.exe
tm1top.ini
TM1ULibDll.dll
zlib1.dll
C
N
ssl
gsk8acmeidup_64.dll
gsk8cms_64.dll
gsk8dbfl_64.dll
gsk8drld_64.dll
gsk8iccs_64.dll
gsk8kicc_64.dll
gsk8km_64.dll
gsk8ldap_64.dll
gsk8msca_64.dll
gsk8mscng_64.dll
gsk8p11d_64.dll
gsk8p11_64.dll
gsk8ssl_64.dll
gsk8sys_64.dll
gsk8valn_64.dll
log4cxx.dll
log4cxxw.dll
msvcp100.dll
msvcr100.dll
tm1api.dll
tm1top.exe
tm1top.ini
TM1ULibDll.dll
zlib1.dll
