Server Crash Due To Page File
kenship
OLAP Product: Cognos
Version: Planning Analytics 2.0.7
Post by kenship »
One of our instance has been crashing 3 times for the last 2 days. The immediate reason is that there was no more free disk space for read and write of temporary files. At worst only 80k was available before crash. We have a small model and here's what I know about our setup:
Total memory = 32GB
Total disk space = 100GB
Total file size = 40 GB
Total memory used according to StatsForServer normally = 6GB
Total memory for cubes according to StatsForCube = 5GB
We noticed that all available disk space (60GB) was taken up as page file before crash, StatsForServer before crash reported the following:
Number of Connection: 27
Number of Active Threads: 27
Memory Used: 98,345,277,816
Memory in Garbage: 352,064,512
Memory used and active threads were way too high compared to our normal (6GB and 3-5 active threads).
We checked the log and couldn't find anything meaningful to diagnose the situation. IT told us that the page file size grew quickly but we don't know the cause of it.
Any comment, suggestion to what we should look at is greatly appreciated.
Kenneth
Re: Server Crash Due To Page File
I don't know all the ins and outs of the technicalities about paging files but I will tell you that, based on my experience, you are crazy to run TM1 on a server where the available disk space is only a factor of 3 times larger than the memory you have installed in your server. This should be more like a factor of 10 or more.
Post by David Usherwood »
Turn on Performance Monitor and study }StatsbyCube and }StatsforServer - that should tell you what's eating memory (and thus your pagefile).
May also be worthwhile deleting your feeder files if you are using persistent feeders, especially if you have been making rule changes and other structure changes.
From some dev environments I have noticed that you can accumulate a lot of rubbish which then seems to be loaded, even if not needed, purely because it is in the feeders file.
BR, George.
Have you by any chance got any CA reports looking at (the new) hierarchies?
The issue should be relatively easy to diagnose just by monitoring the DB and the stats cube, you have a repeatable issue. You'll need to monitor what's going on inside the DB, the external stat you list don't really help other than it is using a bunch of RAM for some reason.
kenship
Post by kenship »
Here's the interesting thing, we haven't loaded or modified any new dimension, cube, hierarchy whatsoever.
When the memory from server stat reached 98G, my cube stat totals 6G only, which gives me no clue of which cube is giving me issue.
Kenneth
Steve Rowe wrote: Thu Mar 01, 2018 6:00 pm Have you by any chance got any CA reports looking at (the new) hierarchies?
kenship wrote: Thu Mar 01, 2018 6:09 pm Here's the interesting thing, we haven't loaded or modified any new dimension, cube, hierarchy whatsoever.
Have you been loading data via SQL by any chance? Noticed a similar increase in memory at a client, luckily did not crash but seem to remember garbage collection also sitting with quite a lot of memory used.
P.s. not exactly sure if you meant loading cubes or loading data into cubes.
BR, George.
kenship
Post by kenship »
We have one daily process. It ran about 9 hours before crash, didn't notice any error message.
What I meant by loading means running TI to load csv file for building dimension. What I meant to say was we were not doing anything out of ordinary for the last few years.
Right now I'm monitoring the free space available and it hasn't changed much since server restart about 22 hours ago.
Kenneth
gtonkin wrote: Thu Mar 01, 2018 6:22 pm
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
I wasn't directly involved but seem to remember a server crash where the error said paging file was too small. I think the problem related to the fact that in one of the CFG files a server AdminHost was pointing to the live URL and not the test environment.
Hope that at least rules out one possibility!
cheers, Mark
