I have upgraded tm1 version 10.2.2 to PA 2.0.3. But there is one critical report view slowed down, where in the condition before the upgrade is 15-20 seconds and after the upgrade to 25-30 seconds. is there any cause that makes a performance difference? is there a custom configuration that needs to be set in PA 2.0.3 ?
Thanks.
Report view slowed down after upgrade TM1 version 10.2.2 to PA 2.0.3
looksout17
- OLAP Product: Planning Analytics and TM1
- Version: 2.0.3 and 10.2.2
- Excel Version: 14
Willi
- Version: 9.5.2
Re: Report view slowed down after upgrade TM1 version 10.2.2 to PA 2.0.3
Do you probably need adjustments on VMM and VMT in the }CubeProperties Cube?
MEB
- Excel Version: Office 2010
Could you expand on what kind of adjustments might be needed?
Willi
- Version: 9.5.2
I think this Blog-Post explains the use of this 2 entries much better than I can. So probably the upgrade gets the used cube a bit over the threshhold.
