I have multiple worksheets in a workbook and all worksheets except one is correctly displaying the values (DBRWS). The issue is everything on the this worksheet is coming bold. I have tried various methods, bolding and unbolding again and updating on tm1 web, however this particular worksheet still shows everything bold. Has anyone seen this issue....Kindly help
TM1 Web showing Bold
- Excel Version: Excel 2013
Re: TM1 Web showing Bold
Is it a worksheet using an Active Form? If so, have you checked the formatting definitions for that Active Form?
- Version: PA 2.0.6 Local
- Excel Version: Excel 2016
If it's not a formatting problem then I wonder if it's http://www.ibm.com/support/docview.wss? ... SS9RXT-_-R?
The heading is : PI91427: TM1 WEB SHOWS IN BOLD SOME LINES OF A WEBSHEET WHILE IN PERSPECTIVES THOSE LINES ARE NOT IN BOLD
Not that there seems to be any detail in there as to a fix unfortunately.
- Version: Planning Analytics
Thanks AndreAndre_Wium wrote: ↑Fri Jan 12, 2018 6:00 am Is it a worksheet using an Active Form? If so, have you checked the formatting definitions for that Active Form?
Thanks TJMurphyTJMurphy wrote: ↑Sat Jan 13, 2018 11:06 am If it's not a formatting problem then I wonder if it's http://www.ibm.com/support/docview.wss? ... SS9RXT-_-R?
