Error upgrading PAW
hardstep
OLAP Product: TM1, EP, Powerplay, C8/C10
Error upgrading PAW
Post by hardstep »
Hi there,
I am trying to upgrade my PAW version from v24 to v28 (runner docker & virtualbox in windows).
I have extracted the new PAW v28 into a new directory and copied over the old paw.env file to the new install directory.
When I try to run start.bat I get an error message start-2017-12-20-16-48-09.txt
(This is after answering Y to update the docker image)
When I try to run start.bat as administrator I get the following new error message : start-2017-12-20-16-53-51.txt
Historically this has worked fine upgrading from previous version up until v24, but it has stopped working :-(
Anyone had similar issues ?.
Festive Cheers !
N
start_2017_12_20_16_53_51.txt
(539 Bytes) Downloaded 398 times
start_2017_12_20_16_48_09.txt
(765 Bytes) Downloaded 424 times
dr.nybble
Excel Version: Excel 2007
Re: Error upgrading PAW
Post by dr.nybble »
Try to start the VM from Oracle VM VirtualBox. Any helpful output on the console?
hardstep
Post by hardstep »
Hi Dr Nybble !.
I’ve checked the console in virtualbox and nothing obvious in there.
The vm image appears to boot fine, no errors showing.
IBM discussion forum suggests looking at disk space issues, but not seeing any disk related errors.
Have you seen any install & troubleshooting docs or blogs on your tm1 time travels ?, there appears to be very little in the way of taming and troubleshooting paw and the beast that is docker :-(
Festive cheers
Nick
codingCPA
Version: Planning Analytics 2.0.21, PAW
Excel Version: Excel 2013
Post by codingCPA »
You may not necessarily get any related errors if you have disk size or memory availability issues related to the vm. I have seen instances where the vm appears to be have started, but the PAW services never actually come up because the containers were never able to fully load into memory. When you run 'docker container stats' in the shell how many services are fully up and running?
