IBM Planning Analytics Active Directory
Anusha
Post by Anusha »
Hello All,
I am trying to create active directory users in planning analytics.I have updated the tm1s.cfg file with the IntegratedSecurityMode=5 and added active directory users in TM1 configuration file. But unable to login with active directory users.Do I need to make any other configuration please advice
Hoping somebody can assist me.
Anusha.
TM1 options.PNG (26.44 KiB) Viewed 5105 times
TM1 Integration error.PNG (17.16 KiB) Viewed 5105 times
TM1 Login Error.PNG (14.33 KiB) Viewed 5105 times
kangkc
Version: 2.x
Excel Version: 36x
Re: IBM Planning Analytics Active Directory
Post by kangkc »
http://www-01.ibm.com/support/docview.w ... wg22000283
Many steps to follow but this is the only way now for all PA components.
Alternatively you can wait for the next update from IBM which promise a mode 3 with PAW.
ckoenig
Post by ckoenig »
i guess this is the right document:
https://www.ibm.com/support/knowledgece ... _cont.html
the other is describe the Settings using SSO. This is not needed if you want to use AD only ( write the credantials during login )
Chris
