Child Elements are not visible under consolidations
vishalpoddar90
Version: 2.0.76
Excel Version: 365
Post by vishalpoddar90 »
Dear All,
I am creating a dimension with C level elements as last 5 week, last 10 week and last 13 week through TI.
Now when I open the Dimension I am not getting all the elements under consolidations. but as soon as i click collapse and reexpand the same consolidated element then I get all the elements under it.
Kindly help me to resolve this issue.
Re: Child Elements are not visible under consolidations
Hi this is not an issue but expected behaviour.
The no-named subset view of a dimension you get when you open the subset editor is the natural underlying order of the dimension, which by default is I think the order in which the elements were added.
You can fix the natural order of the dimension in the dimension properties cube or using a TI command (DimensionSortOrder)
vishalpoddar90
Version: 2.0.76
Excel Version: 365
Steve Rowe wrote: Mon Oct 30, 2017 1:53 pm Hi this is not an issue but expected behaviour.
I used DimensionSortOrder(DimensionName, 'ByInput', 'Ascending', 'ByHierarchy','Acending'); but it didnt nade any difference.
i have created a subset with mdx expression hierarchize but still getting the same results.
What tab did you run the dimensionsortorder on?
vishalpoddar90
Version: 2.0.76
Excel Version: 365
declanr wrote: Mon Oct 30, 2017 2:02 pm What tab did you run the dimensionsortorder on?
I have tried with Prolog, metadata and epilog. Same result with all three tabs.
tm123
OLAP Product: tm1, cognos bi
Post by tm123 »
Subset editor shows elements only once, so if you have multiple hierarchies in the dimension, it will not expand them all.
vishalpoddar90
Version: 2.0.76
Excel Version: 365
tm123 wrote: Mon Oct 30, 2017 2:34 pm Subset editor shows elements only once, so if you have multiple hierarchies in the dimension, it will not expand them all.
Then how to show all elements. I want to automate it. I have created a dyanamic subset using mdx expression but still getting same results.
tm123
Post by tm123 »
did you try to use { HIERARCHIZE( YourMDX ) } ?
vishalpoddar90
Version: 2.0.76
Excel Version: 365
tm123 wrote: Mon Oct 30, 2017 4:30 pm did you try to use { HIERARCHIZE( YourMDX ) } ?
Yes, i tried that also bt still no success.
tm123
Post by tm123 »
What version of TM1 are you using and also can you please post a screenshot from your Subset Editor, with MDX Expression Windows being displayed
What exactly are you expecting to see when you open the dimension? Are you expecting to see last 5 week, last 10 week and last 13 week, in order, all drilled down to their lowest level? If it is then just use this MDX in a subset:
{TM1DRILLDOWNMEMBER( {[YourDimName].[last 5 week]}, ALL, RECURSIVE )}+
{TM1DRILLDOWNMEMBER( {[YourDimName].[last 10 week]}, ALL, RECURSIVE )}+
{TM1DRILLDOWNMEMBER( {[YourDimName].[last 13 week]}, ALL, RECURSIVE )}
vishalpoddar90
Version: 2.0.76
Excel Version: 365
tomok wrote: Mon Oct 30, 2017 6:52 pm What exactly are you expecting to see when you open the dimension? Are you expecting to see last 5 week, last 10 week and last 13 week, in order, all drilled down to their lowest level? If it is then just use this MDX in a subset:
Thanks a lot for expression but still I am getting same result.
Can you supply screenshots please ?
Also, the .dim file for the relevant dimension.
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
This MDX may return the elements you require:-
, {TM1DRILLDOWNMEMBER( {[YourDimName].[last 10 week]}, ALL, RECURSIVE )}
, {TM1DRILLDOWNMEMBER( {[YourDimName].[last 13 week]}, ALL, RECURSIVE )}
vishalpoddar90
Version: 2.0.76
Excel Version: 365
Wim Gielis wrote: Tue Oct 31, 2017 7:46 am Can you supply screenshots please ?
As per my organization's restriction I am not allowed to post any files or screenshots.
