Hi ,
I have a hierrachy like Region, Agency,Subregion, Rep and accounts .
The user wants the count of number of accounts under each agency .
Is there a TI function I can use which will take the agency as input and give me the count of accounts under that agency .
Count the number of Accounts for each agency
Analytics123
- OLAP Product: Tm1
- Version: 9.5
Re: Count the number of Accounts for each agency
No, but you can always write your own. If it was me I would have a TI that takes the agency as an input, builds an MDX-based subset on the dimension that does a TM1DRILLDOWNMEMBER on that input agency and then filters to only 0 level. Then you can use SUBSETGETSIZE on that subset. That will give you the number of accounts under the agency.Analytics123 wrote: ↑Fri Oct 20, 2017 7:22 pm Is there a TI function I can use which will take the agency as input and give me the count of accounts under that agency .
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Please go through the MDX primer.doc for detail explaination of MDX functions with context to TM1. Thanks
- MDX_Primer.doc
- (669 KiB) Downloaded 654 times
