Writing a TI Process to Create Dynamic Subsets
DNA_DC
- OLAP Product: TM1 and Cognos EP
- Version: 9.4
I promise to contribute to the discussion when I am more knowledgable about this but how would I write a TI process to create dynamic subsets for every change in values of a particular attribute. Lets use the example I used earlier:
For every new "Sponsor" (attribute in the Organizations function), create a new dynamic subset that shows only the elements that have that particular "Sponsor" as an attribute value.
Help is definitely appreciated!
- Martin Ryan
- Version: 10.1
Re: Writing a TI Process to Create Dynamic Subsets
Not sure off the top of my head, but have a look in the manual under TI functions, there's something in there about creating subsets based on MDX expressions.
To get the right MDX expression you might have to play around with Tools -> Record Expression in Subset Editor to record the MDX query. You'll need to have View -> Expression Window checked.
Martin
Martin
Jodi Ryan Family Lawyer
DNA_DC
- Version: 9.4
I get that part... the thing thats difficult is creating new subsets "automatically" as new "Sponsors" are loaded from data.
- Martin Ryan
- Version: 10.1
I'd do one of two things
1) As new sponsors are loaded up, create a new dimension called 'Sponsors' (actually, I think you already have this?) then once the load process is created call another process that cycles through the 'Sponsors' dimension and uses the elements in this dimension to create the subsets
2) Instead of cycling through a specially created dimension, cycle through the 'Organizations' dimension and retrieve the sponsor attributes and use them to create the subsets. Again this will be in a separate process.
Martin
Martin
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
Since it sounds like your MDX might get a little complex for the Subset Editor you also might look into the MDX Primer that is in this forum. It has a pretty good overview of MDX if you have not worked in it before.
But like Martin stated there is no "automatic" way to do, processes are your only option.
DNA_DC
- Version: 9.4
The part of the process I am having trouble with is "cycling' through the attributes to find unique attributes and create a subset of them. I tried a "while ( index > dimsiz('dimensionname') ) loop but to no available.
-DN
-DN
DNA_DC
- Version: 9.4
the code below does create the first subset (albeit not dynamic) but does not create the subsequent subsets:
If I use the following "SubsetCreateByMDX" code, it doesn't recognize "SponsorName":
However, if I run this code, it creates the first dynamic subset:
So in the end, there are two problems:
- The While statement doesn't work as needed
- The MDX statement doesnt recognize the variable.
What do you guys recommend?
#declaring variables
Index = 1;
FunctionSize = dimsiz('Functions');
SponsorName = attrs('Functions',DIMNM('Functions',Index),'Resource Sponsor');
#while loop to cycle through all of the Resource Sponsors
While (index < FunctionSize );
If( SubsetExists('Functions',SponsorName) = 0);
SubsetCreate('Functions', SponsorName);
Index = Index + 1;
ElseIf( SubsetExists('Functions',SponsorName) = 1);
index = index + 1;
ENDIF;
END;Code: Select all
Index = 1;
SubsetCreatebyMDX(SponsorName,'{FILTER( {TM1SUBSETALL( [Functions] )}, [Functions].[Resource Sponsor] = SponsorName)}');
Index = Index + 1;
index = index + 1;
ENDIF;
Index = 1;
SubsetCreatebyMDX(SponsorName,'{FILTER( {TM1SUBSETALL( [Functions] )}, [Functions].[Resource Sponsor] = "A")}');
Index = Index + 1;
index = index + 1;
ENDIF;
END;- The While statement doesn't work as needed
- mattgoff
- Version: 10.2.2.6
- Excel Version: O365
You need to move:
inside your while. As written, it never changes after index 1.
Matt
SponsorName = attrs('Functions',DIMNM('Functions',Index),'Resource Sponsor');Matt
DNA_DC
- Version: 9.4
As you suggested, I changed the code (below):mattgoff wrote:You need to move:
inside your while. As written, it never changes after index 1.Code: Select all
Matt
Index = 1;
ENDIF;
Index = Index + 1;
END;Error: Epilog procedure line (16): Name "" contains an invalid character
DNA_DC
- Version: 9.4
Nevermind! Got it to work!!! (See Code Below):
Index = 1;
If( SponsorName @<>'' );
ENDIF;
ENDIF;
Index = Index + 1;
END;-
DNA_DC
- Version: 9.4
But now I need to figure out how to get the MDX statement to accept the SponsorName variable... any pointers?
I am also trying an alternative approach (which is still giving me errors):
Basically, when I run it, it says:
I'm trying to figure out why... if anyone can resolve that, it would be spectacular!
Index = 1;
SubsetIndex = 1;
SubsetIndex = 1;
SubsetElementInsert('Functions', SponsorName, SUBNM('Functions', 'All', Index), SubsetIndex);
SubsetIndex = SubsetIndex + 1;
Else;
ENDIF;
ENDIF;
Index = Index + 1;
Error: Epilog procedure line (24): Subset not found-
DNA_DC
- Version: 9.4
As an update, I solved it... in case someone wants to use it, here's the generalized code:
Index = 1;
Reference_Dim_Size = dimsiz('Reference_Dim');
#while loop to cycle through all of the Resource Sponsors and create the subsets
While (index < Reference_Dim_Size );
Attribute_Name = attrs('Reference_Dim',DIMNM('Reference_Dim',Index),'MyAttribute');
SubsetPre = INSRT('My Attribute Subset ', '', 1);
If( Attribute_Name @<>'' );
SubsetName = SubsetPre | Attribute_Name;
If( SubsetExists('Reference_Dim',SubsetName) = 0);
SubsetCreatebyMDX(SubsetName,Expand('{FILTER( {TM1SUBSETALL( [Reference_Dim] )}, [Reference_Dim].[MyAttribute] = "%Attribute_Name%")}'));
ENDIF;
ENDIF;
Index = Index + 1;
END;
