Unwanted TM1 dimension hierarchy levels showing up in Cognos report(Solved)
escape18in
OLAP Product: IBM Cognos BI
Excel Version: Excel 2010
Post by escape18in »
My TM1 Cube is used in a Cognos report. i am pulling a leaf level data from TM1 to Cognos report. suddenly one of my dimension showing up unwanted concatenated hierarchy for most of elements instead of leaf level element. Can anyone tell what should be the issue?
jim wood
Version: PA 2.0.7
Re: Unwanted TM1 dimension hierarchy levels showing up in Cognos report
Post by jim wood »
escape18in
jim wood wrote: ↑Wed Sep 20, 2017 1:43 pm You might want to look at this:
http://www.tm1forum.com/viewtopic.php?f ... 887#p66832
Tried RefreshMdxHierarchy('') but it did not work for me.
I vaguely remember that this could happen if elements were in more than one consolidation in the dimension.
qml
Excel Version: 2007 - 2016
Post by qml »
Steve is right. Cognos BI needs a single, unique hierarchy path to each element. If there is more than one, because e.g. there are alternate hierarchies, it will use the full path to identify an element. And what is more, from Cognos's perspective each one of the instances of that element in the hierarchy tree will be treated as a different element, even though from TM1's perspective they are all one and the same.
Kamil Arendt
escape18in
Re: Unwanted TM1 dimension hierarchy levels showing up in Cognos report(Solved)
Thanks guys for reply.yes you guys are right there were more than one consolidation in my dimension which was causing this issue i corrected it and everything is fine.
