hi guys,
i m tring to export data from a cube using ASCIIOutput on a TurboIntegrator process, and on txt export i have a string that contain a carriage return character,
i ve tried to cleansed in the same TI with DELET (pString, SCAN(CHAR(13), pString),1) but it didnt work
do you have any other suggestion
Best regards
Clean a carriage return character
- jim wood
- Version: PA 2.0.7
Re: Clean a carriage return character
As long as you set your field quote character (default ") you should be ok. I guess it depends where the data is going? If it's going back in to TM1 you should be good.
zbhmida
- OLAP Product: IBM Planning Analytics
- Version: 2.0.93
- Excel Version: 2 0 94 7
Hi Jim,
Yes its going back to TM1,
and Yes the DatasourceASCIIQuoteCharacter='';
i ll try
thank you for your reply
Zied
i ll try
Zied
zbhmida
- Version: 2.0.93
Well,
i have tried:
it works but the string is not loaded totally,
i explain:
LF = CHAR(13) = carriage return caracter,
pString = "tissu S31 'LF'
Partiel des fournitures 7/8" 'CR/LF'
Before i tried new code i had *ERR* on TM1 Cube, and after that i had "Tissu S31" and not all the string,
Any suggestions
Thank you in advance,
Zied
i have tried:
nLength = Long(vValeur);
nScan = SCAN(CHAR(13), vValeur);
IF(nScan >0);
vValeur = SubSt(vValeur,1,nScan - 1) | ' ' | SubSt(vValeur,nScan + 1,nLength);
endif;i explain:
Any suggestions
Zied
- jim wood
- Version: PA 2.0.7
Well the only thing I can suggest is doing a scan for carriage return ascii character. I can't remember its number but I believe it has one,
Now it will become evident:
DatasourceASCIIQuoteCharacter = '';
vValeur = 'A ' | Char( 10 ) | ' B ' | Char( 13 ) | ' C ';
AsciiOutput( 'test.txt', vValeur );
# replace CRLF
nLength = Long( vValeur );
nScan = Scan( Char(13), vValeur );
If( nScan > 0 );
vValeur = Subst( vValeur, 1, nScan - 1 ) | ' ' | SubSt( vValeur, nScan + 1, nLength );
EndIf;
AsciiOutput( 'test.txt', '' );
# replace LF
nScan = Scan( Char(10), vValeur );
If( nScan > 0 );
EndIf;
AsciiOutput( 'test.txt', vValeur );Best regards,
zbhmida
- Version: 2.0.93
Thank you wim,
it works now ^^
Thk you guys
Best regards
it works now ^^
Thk you guys
Best regards
You're welcome
