SubsetElementGetIndex TI function
- gtonkin
Saw this documentation update tonight and thought it may be useful to some - needs 10.2.2 FP6 however.
I guess it is not really returning the index of the element in the subset that is useful - for me right now being able to test if an element is part of the subset is probably more useful i.e. having a zero returned indicating element is not within the subset.
Re: SubsetElementGetIndex TI function
There's also going to be a CubeGetDimensionCount. Although it's clearly been a missing function there are more important things I would have focused on given the chance.qml wrote:Wow. SUBIX. Finally.
If the function SubsetElementDelete only takes an index instead of an element name, I would be interested in the index number in the subset.gtonkin wrote:I guess it is not really returning the index of the element in the subset that is useful
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
The key thing is that by specifying a start index they have given a way of iterating over all the occurrences of an element in a subset.
There is a ER for SubsetElementDeleteByName if you want to vote for it.Wim Gielis wrote: ↑Tue Aug 30, 2016 12:15 pmIf the function SubsetElementDelete only takes an index instead of an element name, I would be interested in the index number in the subset.gtonkin wrote:I guess it is not really returning the index of the element in the subset that is useful
http://www.ibm.com/developerworks/rfe/e ... _ID=108338
Upvote from me; you seem to have considered all of the angles including when it should and shouldn't fail. (Let's not get started on TI still not having Try / Catch or any other real error handling, but that aside...)lotsaram wrote: ↑Thu Jul 27, 2017 8:52 amThere is a ER for SubsetElementDeleteByName if you want to vote for it.Wim Gielis wrote: ↑Tue Aug 30, 2016 12:15 pmIf the function SubsetElementDelete only takes an index instead of an element name, I would be interested in the index number in the subset.gtonkin wrote:I guess it is not really returning the index of the element in the subset that is useful
I voted too !
There's also an ER for SubsetAliasGet while you're at it!
http://www.ibm.com/developerworks/rfe/e ... _ID=109262
You got my vote, I have been in the same boat of reading out *.SUB files, which is an unnecessary overhead.
