I have a problem with manage rights from my TM1 Web Applications. When i tried to save my rights i had an error "An error occurred while creating Cognos objects".
I added the Clients and Groups from Cognos BI in Architect and after i tried to save my rights i received this error.
I saw the logs from TM1server.log (on attachement) i have some errors:
8960 [28] ERROR 2017-08-01 09:42:36.488 TM1.Mdx.Interface Syntax error at or near: '[}ElementCaptionsByDimension] WHERE([}Di ... ', character position 88
8960 [28] ERROR 2017-08-01 09:42:36.492 TM1.Mdx.Interface Syntax error at or near: '[}ElementCaptionsByDimension] WHERE([}Di ... ', character position 88
8960 [28] INFO 2017-08-01 09:42:36.560 TM1.Process Process "}tp_modify_application_attribute" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.562 TM1.Process Process "}tp_modify_application_attribute": finished executing normally, elapsed time 0.00 seconds
8960 [28] INFO 2017-08-01 09:42:36.662 TM1.Process Process "}tp_job_end" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.664 TM1.Process Process "}tp_job_end": finished executing normally, elapsed time 0.00 seconds
8960 [28] INFO 2017-08-01 09:42:36.766 TM1.Process Process "}tp_set_running_maintenance" executed by user "AD/Ana Ventura"
8960 [28] INFO 2017-08-01 09:42:36.768 TM1.Process Process "}tp_set_running_maintenance": finished executing normally, elapsed time 0.00 seconds
I saw that the prefix from Table Select Group in TM1 Web Applications show the group different way, it has a slash and not the backslash (Cognos/<group>). I spouse that the bar it is important for this process. (i send you the image in attachment)
How can i solve this problem?
Thank you,
Ana Ventura
Admin Note: Please do NOT post into the Enhancements Forum unless you are asking for an enhancement as defined here. This post has been moved.
Manage Rights error Cognos Planning Analytics V2.0.X
Ana Ventura
- OLAP Product: SSAS, TM1
- Version: 10 2 2
- Excel Version: 2013
