I thought I would quickly copy and paste data from February to the remainder of the year by selecting the data in the cube view and pasting across the months.
My view had some products on the rows (95 of them) and Jan-Dec on the columns. Jan+Feb were ruled derived and Mar-Dec were STET'ed.
I copied my 95 cells worth of numeric data and pasted into my massive matrix of 95x10 - almost two minutes later I had my results.
This seemed a little slow so decided to do a r>|1 from the first product in Mar - eventually my 95x10 grid was filled - not much quicker if any.
I then sliced the view to Excel and used DBSW to send Feb to Mar-Dec - Instant! WTF?
Anyone else having this?
p.s. The cube has very little data and the rules are copying from Actual to Forecast for Jan and Feb.
TM1 is 10.2.2 FP3 IF1 (or whatever the re-release is called)
I have patched all my systems and thus have not tried an older version of TM1 yet.
Cube viewer - copy and paste so very slow
Re: Cube viewer - copy and paste so very slow
Any chance you had the Automatic Recalc button toggled on in the cube view without realising? The icons in the V10 series have such crystal clarity that it's not hard to do.gtonkin wrote:I thought I would quickly copy and paste data from February to the remainder of the year by selecting the data in the cube view and pasting across the months.
I can't remember whether it's in one of my old videos or one of the new ones that I haven't posted yet, but I do recall that I say of that button: "Don't use it. Dooooon't use it. Just... don't use it is all." Things like what you're describing are why.
- gtonkin
Thanks Alan, Auto-calc was definitely off.
Going to try bring the same system up on 9.5.2 later and post results once tested.
- gtonkin
Using Cube Viewer through Architect I tested copying and pasting as well as spreading with repeat - 1 column, 64203 rows - results are as follows:
One the Pasting test we used another session to see what is happening - looks like each cell is updated one by one, no batch update.
Spreading seems to use a batch update/commit
Using a DBSW to populate values from Excel to cube results in times similar to the spreading in 9.5.2 when testing on 10.2 flavours - about 4 seconds to send 64203 values.
Using a data spread on DBRW formulae also takes about the same time as 9.5.2, no noticeable difference. Takes longer for the Right-click context menu to appear than to spread.
Conclusion
Avoid pasting data in the cube viewer if you can
Cube viewer appears to have become crippled!
p.s. for those who care, the following made no difference: MTQ changes, removing rules, ForceReevaluationOfFeedersForFedCellsOnDataChange etc. etc. etc.
Operation/Version | 9.5.2 (9.5.20300.29580) | 10.2.1 (10.2.20100.83) | 10.2.2 FP3-IF1 (10.2.20300.98) FP3-IF1 |
Data Spread Repeat | 8 seconds | 8 minutes | just under 5 minutes |
Data Spread % Change | 8 seconds | 8 minutes | just under 5 minutes |
Paste | 10 minutes | did not test | cancelled-~infinity |
Conclusion
I haven't noticed any issues along these lines. Or at least not on the scales you are noticing but that being said I have always found pasting HUGE volumes into cubeviews to be slow - but in day to day use you wouldn't expect end users to be doing such a huge volume paste anyway so I don't have to tackle it very often.
Note that between 9.5.2 and 10.1 IBM significantly changed the default actions of some config parameters (such as PI) and then the same again for 10.1 to 10.2; so I would expect that maybe the issue partly resides with it not really being a like for like test.
- mce
- Version: Planning Analytics Local 2.0.x
- Excel Version: 2013 2016
I observed the same problem there in Cube viewer. Copy and Paste takes ages...
