I need to have 2 data sources in a TI Process. One data source I am having as a cube view, I also need some information from Excel file into this TI Process as well. In the data source I have defined the cube view. How shall I get the csv file read now?
2 data sources in 1 TI Process
pooja_11284
Re: 2 data sources in 1 TI Process
You will need 2 processes.
Just to elaborate on what Wim said, if you need data from the text file while you are doing the cube view-based process (which you may be implying, though your question isn't completely clear), the workaround would be to load the text file into a temporary cube first. When you run the cube view-based process you could then read whatever you need from the temporary cube via CellGetN / CellGetS functions.pooja_11284 wrote:Hi,
pooja_11284
Yes You are right Alan. Thanks I got it.
