IBM Planning Analytics On Prem
Re: IBM Planning Analytics On Prem
Post by David Usherwood »
@Gabor, did you test this? Tried it just now and it did not work for me - using both 'tm1server' (IBM's version) and TM1Server (your version).
Gabor
Version: [2.x ...] 11.x / PAL 2.0.9
Excel Version: Excel 2013-2016
Post by Gabor »
Hi David,
using "TM1Server" the services at least appear in older clients. Then I see it working for a few seconds after a double click, but it never returns with a login prompt.
This looks like a port issue in the past, but I am still waiting for feedback from IBM.
Gabor
Post by Gabor »
UseSSL=F in tm1s.cfg has finally enabled the older client(s) under 11.0.x. The Admin Server can still be Non-SSL=False in Cognos Configuration.
Didn't work for me.
