How to exit LOOP in TM1 TI?
Ashleigh W
Version: TM1 Perspectives 10
Excel Version: Excel 2016
Post by Ashleigh W »
Hi, how to exit LOOP if certain condition is met in TM1 TI? Is below the correct way?
nNum = 1;
While( nNum <= 7 );
sNum = NumberToString( nNum );
IF( EXPAND( '%v' | EXPAND( '%sNum%' ) | '%' ) @= 'Test' );
 END;
ENDIF;
nNum = nNum + 1;
END;
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Re: How to exit LOOP in TM1 TI?
Post by TrevorGoss »
Ashleigh W wrote:Hi, how to exit LOOP if certain condition is met in TM1 TI? Is below the correct way?
nNum = 1;
While( nNum <= 7 );
 END;
ENDIF;
nNum = nNum + 1;
END;
you can use the Break keyword from 10.x onwards.
Example:
x = 1;
While(x <= 10);
	x = x + 1;
	If(x = 5);
		Break;
	EndIf;
End;
Use Break.
Please indent your code and use EXPAND only where it should be used.
nNum = 1;
While( nNum <= 7 );
  If( Expand( '%v' | NumberToString( nNum ) | '%' ) @= 'Test' );
    Break;
  EndIf;
  nNum = nNum + 1;
End;
Ashleigh W
Thanks guys!
