control cube asciioutput
Moh
OLAP Product: Cognos
Version: 10.1.1
Post by Moh »
Good morning sir,I need to export cube }client properties dimension }client properties which has alais }tm1_defsultdispalyvalue(alias) iam needing all the users in tm1.please explain.
Re: control cube asciioutput
Hello
What code do you already have? A while ... end loop over the }Clients dimension? Use ATTRS to retrieve the value of the attribute.
Moh wrote:Good morning sir,I need to export cube }client properties dimension }client properties which has alais }tm1_defsultdispalyvalue(alias) iam needing all the users in tm1.please explain.
There is really only one thing to say to this and you will find it expressed quite nicely here.
