Hello Folks,
As we can see, the Planning Analytics can't run a TI process natively (only using a sheet in perspectives).
Anyone knows if have a way to run a process using a URL? Any advice to run a TI process via portal?
I tried to use the link below, but no sucess.
https://www.ibm.com/developerworks/comm ... 08f8fc2eff
Thanks!
Planning Analytics - Run TI Process Passing URL
- tianoklein
- Excel Version: 2013
- Version: 9.5.2 10.1 10.2 PA2
Re: Planning Analytics - Run TI Process Passing URL
What errors are you getting when following those instructions?
It's important to note that just using a URL like that in a browser link won't work. The browser will make a GET request while the API requires a POST request with a body.
- tianoklein
Hello BrianL,
I create a html file and nothing happen.
<html>
<body>
<form action="https://_HOST_:_PORT_/tm1/api/v1/Processes('testP')/tm1.Execute" method="post">
<button type="submit">Submit</button><br>
</form>
</body>
</html>
The HTML form POST action does not allow arbitrary body text or even JSON formatted body text. That's why your example isn't working. Javascript is probably your best bet. Try googling 'javascript POST JSON'.
- tianoklein
Hi BrianL,
I'm no good making javascripts /JSON scripts
Am I going to the right way?
<html>
<body>
<script>
var text = '{"name":"Processes","kind":"EntitySet","url":"https://_host_:_port_/tm1/api/v1/Processes('test')/tm1.Execute"}';
var obj = JSON.parse(text);
</script>
<form action="obj" method="POST">
</form>
</body>
</html>
- Excel Version: Excel 2007
Try using jquery with the $.post method.
Check the example at the bottom:
https://api.jquery.com/jquery.post/
