My machine is pre-installed with .net framework (versions 1.1, 2.0 SP1 etc) and I have also successfully installed Applix 9.1 SP2 as a stand alone application (TM1 perspectives). In tm1 server explorer, I can perform all operations other than opening a rules editor.
I tried second time by re-installing .net framework 1.1 SP1 following applix installation but was not fruitful.
Can you please let me know where am I going wrong?
Rules editor can't be opened in Applix 9.1 SP2 version?
Re: Rules editor can't be opened in Applix 9.1 SP2 version?
Are you getting any error messages? Are there any error messages in your computer's Application logs? (Right click on My Computer, select Manage, then Event Viewer.)Reddy wrote:Hi
Reddy
- Version: 9.4 FP1
Hi Alan
I see some error messages (pls find attachment) but no error messages logged with todays date.
- Appln_log.docx
- (141.05 KiB) Downloaded 392 times
Reddy
Reddy
Reddy
- Version: 9.4 FP1
Alan, answering to your first question, I did not get any error message while opening the rules editor, when I try to open the rules editor, it remains idle without any error message.
Reddy
Reddy
I suggest you check what your setting in your tm1p.ini file is; see whetherReddy wrote:Alan, answering to your first question, I did not get any error message while opening the rules editor, when I try to open the rules editor, it remains idle without any error message.
AdvancedRulesEditor=T(Then dump it and start using .xrus.
Reddy
- Version: 9.4 FP1
.Alan Kirk wrote:I suggest you check what your setting in your tm1p.ini file is; see whetheris in there. If it's not, add it in and see whether it makes a difference. If that doesn't work try setting it to F instead of T and see whether you at least get the "Classic" Rules editor to work withCode: Select all
Alan, problem is still alive; Can you please clarify whether does this issue has any relation with this below mentioned desc:
"Before installing this applix 9.1 SP2, I have uninstalled TM1 9.4 FP1 completely from the machine, but am doubtful wheteher this has any impact on previous versions (I couldnt see applix logo of .cfg file and also when I run TI, its popping up message "related to UNC path" which was not supported with applix version)..??
Reddy
Reddy
- Steve Rowe
HI Reddy,
You might want to post your error message in a file format that does not require a 30MB download for people not on the latest version of word!
Reddy
- Version: 9.4 FP1
.I suggest you check what your setting in your tm1p.ini file is; see whetheris in there. If it's not, add it in and see whether it makes a difference. If that doesn't work try setting it to F instead of T and see whether you at least get the "Classic" Rules editor to work withCode: Select all
PROBLEM SOLVED!
Alan, I just repeated as per your above suggestion.Now its working fine, ThanX..
Reddy
Reddy
