Business Rules Help
ALAHARI
OLAP Product: cognos Transformer,TM1
Excel Version: 1
Business Rules Help
Post by ALAHARI »
I AM TRYING TO WRITE A RULE MIMICKING AN EXCEL BY COMPARING 2 VALUES IN A CUBE . NOT SURE IF I AM DOING CORRECTLY.
IN EXCEL THE LOGIC IS IF HIGHESTREMOVAL IS 0 THEN NEW ALLOCATION
['FINALALLOCATION' ] = N:IF(['HIGHESTREMOVAL' ] @= 0, ['NEWALLOCATION' ] ,STET);
APPRECIATE YOUR HELP.
Re: Business Rules Help
ALAHARI wrote:Hi
"@=" is for string comparisons. For numeric just use "=".
ALAHARI
Excel Version: 1
Post by ALAHARI »
Thanks!!!!Tom
I am trying to replicate the below string case statement . can you please correct me
excel-=IF(AND(LANDINGS="NO",'CURRENTONHAND'>0),"Excess Stock",
IF(AND(LANDINGS="NO",CURRENTONHAND>0),"Excess Allocation",
['REVIEWCODE' ] = N:IF (!LANDINGS @= 'NO' & ['CURRENTONHAND' ] > 0, 'EXCESS STOCK',CONTINUE);
['REVIEWCODE' ] = N:IF (!LANDINGS @= 'NO' & ['CURRENTALLOCATION' ] > 0, 'EXCESS STOCK');
Perhaps:
['REVIEWCODE' ] = S:IF (!LANDINGS @= 'NO' & ['CURRENTONHAND' ] > 0, 'EXCESS STOCK',CONTINUE);
['REVIEWCODE' ] = S: IF (!LANDINGS @= 'NO' & ['CURRENTALLOCATION' ] > 0, 'EXCESS STOCK', '');
Just to add to Wim's reply you need to use =S: notation to populate a string (text) measure; for this to work you need to make sure that ReviewCode exists in the dimension that is last in order in the cube and is given a string type.
You can also make the code slightly shorter; the !landings notation can go on the left hand side of your rule and you can remove the need for 2 separate statememts:
['NO','ReviewCode']=S:
If ( ['CurrentOnHand'] > 0 % ['CurrentAllocation'] > 0, 'Excess Stock','');
ALAHARI
Excel Version: 1
Post by ALAHARI »
Thanks you guys!!!
