I have a cube that has 3 dimension: EmpName, DeptNum, SupName. The values in EmpName are in the format Name - Employee Number (so as an example it might look like this Jones, Tom - 1234 (same with SupName). 2 records might look like this:
"Jones, Tom - 1234","ABC123","Barker, Bob - 9876"
"Placeholder1","ABC123","Rabbit, Roger - 4561"
I would like to extract the data into a CSV file (I'm using TEXTOUTPUT), but I want to truncate the Employee Number for real employees (1st record), but there isn't trucation needed for the Placeholder employees (as they don't have an employee number. I know that I'm always truncating the last 7 characters. In excel I do something like =LEFT(cell,len(cell)-7).
So it should look like this
"Jones, Tom","ABC123","Barker, Bob"
"Placeholder1","ABC123","Rabbit, Roger"
Not sure what coding I need to do in my TI to accomplish this. I got the extract part (TEXTOUTPUT) in the MetaData tab, just not sure about the text manipulation part.
Any help is appreciated
Simple TI code
Re: Simple TI code
Got the TextOutput part, just haven't figured out the "Placeholder" part
TextOutput('D:/filename.csv',SUBST(EmpName,1,long(EmpName)-7),RC,SUBST(SupName,1,long(SupName)-7));
Re: Simple TI code
You could use, for example, if the presence of - alone is enough to distinguish real names from placeholder names:
If needed, you can add additional logic to see if the last character is a number:
If( Scan( '-', vLongName ) > 0 );
vShortName = Subst( vLongName, 1, Long( vLongName ) - 7);
Else;
vShortName = vLongName;
EndIf;
If( Scan( Subst( vLongName, Long( vLongName ), 1 ), '0123456789' ) > 0);
EndIf;
