Hello Guys,
I have a dimension with multiple hierarchies. There is a n level element which has more than one parent in the different hierarchies of the dimension.
Is there a quick way / mdx to find out all the parents for a particular n level element of the dimension.
Girish
All Parents for n level element
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: All Parents for n level element
This might help:
http://users.skynet.be/fa436118/wim/tm1 ... ing_EN.htm Thanks
madan314
- OLAP Product: Cognos Planning
- Version: 8.4
ELPAR function must help you , Set the Dimension view and following code should help you.
v1 is the variable declared in variables TAB
vHierarchy1 = ELPAR('Dimesnion',v1,1);
vHierarchy2 = ELPAR('Dimension',vHierarchy1,1);
vHierarchy3 = ELPAR('Dimension',vHierarchy2,1);
vHierarchy4 = ELPAR('Dimension',vHierarchy3,1);
BariAbdul
For that matter ,ELPARN is much more relevant to OP and this is what you could see in Wim Gielis post I have shared above ;
ELPARN returns the number of parents of an element in a specified dimension.
Syntax
ELPARN(dimension, element)"You Never Fail Until You Stop Trying......"
gnampoothiry
Thanks BariAbdul
