I'm not sure if it is only me but I find quite "confusing" or not very clear on what the IBM licences allow you and don't allow you to do...
For example if we have a start off package as follows:
1x IBM Cognos Express Manager Connector for Xcelerator Install --- What does this actually entitles you to do?
1x IBM Cognos Express Administrator Authorised User --- What does this actually entitles you to do?
4x IBM Cognos Express Xcelerator User Per Authorised User --- What does this actually entitles you to do?
5x IBM Cognos Express Consumer User Authorised User --- What does this actually entitles you to do?
My understanding in a very simplistic way to see it:
1x IBM Cognos Express Manager Connector for Xcelerator Install --- This allows you to run TM1 in one instance ONLY
1x IBM Cognos Express Administrator --- 1 user ONLY set up as admin in the TM1 security model
4x IBM Cognos Express Xcelerator User --- 4 users set up as read/write ONLY in the TM1 security model. Users can access data via TM1 Perspectives (excel) & TM1 Web
5x IBM Cognos Express Consumer User --- 5 users set up as read ONLY in the TM1 security model. Users can access data via TM1 Perspectives (excel), TM1 Web, any of the other Cognos Express BI tools if availabe such as reporter, planner, advisor.
If we were to have a second TM1 instance (DEV & PROD), we would only need to acquire 1 more IBM Cognos Express Manager Connector for Xcelerator Install.
User licences can access data across several instances
Am I right in saying this? or Do we need 1x licence per user per instance?
Hope any of you can shade a light here
