Corruption of ActiveX objects on 10.2.2 FP5
- gtonkin
Spent my day chasing down something which ultimately looks to be a version issue.
We received a template from a client that had a macro issue - Error 1004 - trying to hide rows and could not shift objects etc. etc.
We could not however move the objects that were problematic as these were TI Buttons (edit-Action Buttons).
It appeared that the worksheet was corrupt as we could not enumerate sheets in the book and do a debug.print of the obj.name
Deleting the TI Button crashed Excel. Numerous other attempts to remove ActiveX controls - TI and Non-TI failed miserably
We attempted the fix on Excel 2016,2013 and 2010 - same behaviour as all three had 10.2.2 FP5 installed.
Whether the add-in was active or not made no difference as the ActiveX seems to look for the TM1XL.OCX file to interpret the button.
@Lotsaram - I know you have done some tinkering on FP5 - would be keen to hear from you on this.
Would be keen to hear if anyone else has had this issue or can replicate.
edit: on FP5, the error raised is something like: Run-time error '32809' Application-defined or object-defined error but have seen various error numbers reported e.g. 57121
Re: Corruption of ActiveX objects on 10.2.2 FP5
Not sure what a "TI Button" is, I presume you mean Action Button. Whenever I've encountered a problem like this (can't say that I've had the EXACT same thing) I load up Excel without the Perspectives add-in loaded, go into Developer Mode. remove the button, and save the worksheet.
- gtonkin
Hi Tom, a TIButton is what the ActiveX control is called once you have added it via the Action Button - you say potato, I say potato
I worked without the add-in loaded for most of the time-going into developer mode and deleting the ActiveX control is what crashed Excel constantly. Repeating my steps with the FP4 client did what I expected however-no crashing and I could manage objects.
Thanks for the reply.
- gtonkin
TM1 10.2.2 FP5 - Sheets with action buttons saved in 10.2.2 FP5 Perspectives can only be read by 10.2.2 FP5 or higher clients (Perspectives and TM1 Web)
Just saw this from IBM - does not address the issues I seem to be experiencing but worthwhile being aware of for when you upgrade!
- Version: 10.2
Did you solve the problem? I have 32809 error after upgrading to 10.2.2 FP5. All clients are FP5 as well.
Action buttons are not working...
“The way to get started is to quit talking and begin doing.” - Walt Disney
- gtonkin
Problem not solved - rolled back to FP4 for now as delivery deadlines loom.
I have also had to roll back TM1 web to FP4 in a couple of places. Action button issues but more so the charts in TM1 web just don't work in FP5.gtonkin wrote:Problem not solved - rolled back to FP4 for now as delivery deadlines loom.
Indeed, charts just do not update - even charts without data from TM1 but just plotting data in cells. FP5 has serious issues there.lotsaram wrote:gtonkin wrote: Action button issues but more so the charts in TM1 web just don't work in FP5.
- Version: 951 952 101 10101
- Excel Version: 2003 2007 2010
Hey, any further updates on this issue. I am wondering if there is any other solution other than reverting back to FP4.
- gtonkin
Nothing to report from my side - holding out for FP6 or 10.3 (Planning Analytics-on premise version)
All the FP6 links posted last week seem to have been retracted - not comforting.
I could see that the issue is with TM1 Perspective client. Wondering if I can use 10.2.2 FP4 perspective client with 10.2.2 FP5 server?
I have tested some functionalities, it seems to be working fine. Has anyone tried such an options?
Dhimant
Dhimant
Yes. Older client newer server works, just not the other way round.dhims wrote:I could see that the issue is with TM1 Perspective client. Wondering if I can use 10.2.2 FP4 perspective client with 10.2.2 FP5 server?
Thanks alot lotsaram
- gtonkin
Found this IBM technote that was posted today in case anyone has this issue in the future.
