TM1 Web: User "Log Out" does not return to Login Screen
- OLAP Product: TM1, PAX, PAW, SPSS
- Version: 2.0.916.10 on RHEL
I was hoping someone might have a solution to or can confirm the following behavior in their environment.
Environment: TM1 10.2.2 with Cognos CAM security (mode 5)
Behavior:
1) User is logged into TM1 Web
2) User session time's out or user clicks "Log Out"
3) User is redirected to what I believe is a BI screen saying:
AAA-AUT-0010
User authentication required. Please Logon.
4) User clicks OK and is redirected to:
http://xxx.com:9510/tm1web/applications.jsp
This is a screen with only the IBM swish background (no options are presented).
To login again, user must manually adjust the URL to:
At this point, novice users are stranded and for experiences users, it's a PITA to get back to the login screen.
Thoughts?
-- John
Behavior:
AAA-AUT-0010
Thoughts?
-- John
- jim wood
- Version: PA 2.0.7
Re: TM1 Web: User "Log Out" does not return to Login Screen
This is to do with CAM. We get the same at the client I'm currently working with. It's not a big issue as they had already expanded the time out length before I arrived. I don't know if anybody has looked in to it.....
Thanks for the confirmation... I'll open a ticket with IBM.
-- John
-- John
BTW, I found this in tm1web_config.xml which seems tantalizingly close to what I wanted, but alas, it doesn't appear to apply to CAM security:
<!-- LogoutUrl to be executed after logout normally completes-->
<add key="CustomCAMLogoutUrl" value="" />
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Hello!image2x wrote:Thanks for the confirmation... I'll open a ticket with IBM.
-- John
Have you got any reply or ticket number from IBM?
Thanks in advance.
Kind Regards,
Peter
Best Regards,
Peter
Peter
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Hi Peter,
Just upgrade to 10.2
http://www-01.ibm.com/support/docview.w ... wg1PM65997
We still see it with 10.2.2 by the way
- Version: 2.0
For those of you seeing this error on 10.2.2, are you only seeing this with CAM security with Single Sign-On enforced?
Matthew Berson
ACG TM1 Consulting
ACG TM1 Consulting
- OLAP Product: TM1 10.2.2
- Version: TM110.2.2
- Excel Version: 2013
Hi!
Just upgraded to TM110.2.2 and face the same issue. Tried providning a value in the logout url but still the asme .. Has anyone got the solution.
- OLAP Product: PowerPlay and Tm1
- Version: 10 2 1
Hello Folks:
I am working on a 10.2.2 upgrade prototype and I am also running into this same issue. Given that this thread is from 2014, I went ahead and installed Fix Pack 4 as well but issue remains.
Any info will be greatly appreciated.
Thanks!
Thanks!
Pretty common issue with 10.2 using CAM authentication ...
- OLAP Product: All of them
- Version: All of them
- Excel Version: 2003 -2013
I had a case like this and the bookmarks used were at fault.
It turned out that all bookmarks used for testing were including the trailing slash, the URL composed by TM1Web though does NOT.
The Load Balancer (in my case) re-directs the URLs which don't have the trailing slash to HTTP which is the root cause.
All documented URLs for TM1Web don't include the trailing slash so it was advised to adjust LB configuration, so that it allows URLs without trailing slash to pass as TM1Web will do the re-direct to a URL with a trailing slash itself. The root cause was found to be outside of the product.
Suggested solution, check your URLs for a trailing slash
- macsir
- Version: PAL 2.0.9
Hi, dsproffittdsproffitt wrote:I had a case like this and the bookmarks used were at fault.
Could you give us some snapshots to see the URLs in the config files need NOT to be included trailing slash?
I dont understand your question.macsir wrote: Hi, dsproffitt
http://servername:portnumber/blah blah/ <-- this is a trailing slash
