Just posting this in case someone gets the same issue.
I had a case where the Dimension Editor was not showing all elements on some dimensions. I remembered that the standard cure for this is to delete the dimed.tbd file. I had recently had to do this for a client who is still on 9.5.1. I just got the same issue on 10.2.2. The file these days is in C:\Users\<user name>\AppData\Roaming\Applix\TM1.
Similar problems with the Subset Editor can be cured by deleting the subed.tbd file.
Both automatically get re-created the next time you open the relevant Editor.
Curing Dimension Editor Corruption
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Curing Dimension Editor Corruption
Thanks a lot,Paul.
