Help for API fuction TM1CubeCellValueGet
kennyyeung
Version: 9.4 MRC
Excel Version: 2000
Post by kennyyeung »
I want to grab data from my cube .But when i use function TM1CubeCellValueGet , it return a error code .
What's wrong with my code?
Cube: Exchange Rate
Dimension : Year
Dimension : Month
Dimension : Currency
Dimension : Rate_m
Private Sub Form_Load()
Dim sServerName As String
Dim sUsername As String
Dim sPassword As String
Dim hUserHandle As Long
Dim pPoolHandle As Long
Dim vPassword, vServerName, vUserName As Long
Dim vStringLength As Long
Dim RetVal As String * 75
TM1APIInitialize
hUser = TM1SystemOpen()
TM1SystemAdminHostSet hUser, "rjordon"
pPoolHandle = TM1ValPoolCreate(hUser)
' We have to take the strings containing the login information (such as the
' user name and password) and turn them into TM1 value capsules.First
' establish the maximum length of the string as 10 characters.
vStringLength = TM1ValIndex(pPoolHandle, 10)
' Next, use this string length to build value capsules for the
' user name, password, and TM1Server name.  We can reuse the pool Handle
' for these functions.
vUserName = TM1ValString(pPoolHandle, "admin", vStringLength)
vPassword = TM1ValString(pPoolHandle, "", vStringLength)
vServerName = TM1ValString(pPoolHandle, "gpdev", vStringLength)
vServerHandle = TM1SystemServerConnect(pPoolHandle, vServerName, vUserName, vPassword)
If (TM1ValType(hUser, vServerHandle) = TM1ValTypeObject()) Then
   ' MsgBox "You Logged in Successfully"
End If
If (TM1ValType(hUser, vServerHandle) = TM1ValTypeError()) Then
    MsgBox "The server handle contains an error code."
End If
Dim year As String
Dim month As String
Dim currency1 As String
Dim rate As String
year = "2009"
month = "April"
currency1 = "EUR"
rate = "rate"
Dim hDimYear As Long
Dim vYear As Long
Dim hDimMonth As Long
Dim vMonth As Long
Dim hDimCurrency As Long
Dim vCurrency As Long
Dim hDimRate As Long
Dim vRate As Long
ReDim elementArray(6) As Long
hDimYear = TM1ObjectListHandleByNameGet(pPoolHandle, vServerHandle, TM1ServerDimensions(), TM1ValString(pPoolHandle, "Year", 100))
vYear = TM1ObjectListHandleByNameGet(pPoolHandle, hDimYear, TM1DimensionElements(), TM1ValString(pPoolHandle, year, 100))
hDimMonth = TM1ObjectListHandleByNameGet(pPoolHandle, vServerHandle, TM1ServerDimensions(), TM1ValString(pPoolHandle, "Month", 100))
vMonth = TM1ObjectListHandleByNameGet(pPoolHandle, hDimMonth, TM1DimensionElements(), TM1ValString(pPoolHandle, month, 100))
hDimCurrency = TM1ObjectListHandleByNameGet(pPoolHandle, vServerHandle, TM1ServerDimensions(), TM1ValString(pPoolHandle, "Currency", 100))
vCurrency = TM1ObjectListHandleByNameGet(pPoolHandle, hDimCurrency, TM1DimensionElements(), TM1ValString(pPoolHandle, currency1, 100))
hDimRate = TM1ObjectListHandleByNameGet(pPoolHandle, vServerHandle, TM1ServerDimensions(), TM1ValString(pPoolHandle, "Rate_m", 100))
vRate = TM1ObjectListHandleByNameGet(pPoolHandle, hDimRate, TM1DimensionElements(), TM1ValString(pPoolHandle, rate, 100))
elementArray(1) = vYear
elementArray(2) = vMonth
elementArray(3) = vCurrency
elementArray(4) = vRate
'create cube handle.
hCubeObject = TM1ObjectListHandleByNameGet(pPoolHandle, vServerHandle, TM1ServerCubes(), TM1ValString(pPoolHandle, "ExchangeRate", 100))
Dim vArrayOfCells As Long
vArrayOfCells = TM1ValArray(pPoolHandle, elementArray, 4)
'set the array values
Call TM1ValArraySet(vArrayOfCells, elementArray(1), 1)
Call TM1ValArraySet(vArrayOfCells, elementArray(2), 2)
Call TM1ValArraySet(vArrayOfCells, elementArray(3), 3)
Call TM1ValArraySet(vArrayOfCells, elementArray(4), 4)
Dim value As Long
value = TM1CubeCellValueGet(pPoolHandle, hCubeObject, elementArrayCapsule)
MsgBox TM1ValType(hUser, value)
' To log out and disconnect from the API, you must
' call TM1SystemServerDisconnect, TM1SystemClose, then TM1APIFinalize.
' In addition, best practice dictates that all TM1 Value Pools used
' in your program be destroyed by calling TM1ValPoolDestroy().
vResult = TM1SystemServerDisconnect(pPoolHandle, vServerName)
' Add Code to delete all TM1 Value Pools here.
TM1ValPoolDestroy (pPoolHandle)
TM1SystemClose hUser
TM1APIFinalize
End Sub
Re: Help for API fuction TM1CubeCellValueGet
Kenny,
If your using VBA you can just use Application.Run("DBR" ,Cube, Dim1, Dim2 etc), is there a reason you can't do this? I assume so but thought I would check..
kennyyeung
Version: 9.4 MRC
Excel Version: 2000
When i run the follow code
>Public Sub Test()
>MsgBox Application.Run("DBR", "ExchangeRate", "2008", "June", "HKD", "rate")
>End Sub
it return *KEY_ERROR
May be i messed up something .
TM1CubeCellValueGet is just my frist step.
More detail on what i am going to do
Actually i want to grab data out by function TM1CubeCellValueGet,
do some calculateion
and then set the data back to the cube by function TM1CubeCellValueSet.
I can perform the function by TI.I just wanna if i could do it though tm1 API
You need to include the server name with the cubename like this "servername:cubename"
kennyyeung
Version: 9.4 MRC
Excel Version: 2000
The get function can work now .Thanks !
The next step for me is to set the data back
is there any function can set the data back to the cube?
Use the DBS formula
answer=application.run( value, "server:cube", ele1, ele2 , etc)
HTH
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
just correcting Steve's typo...
answer=application.run("DBS", value, "server:cube", ele1, ele2 , etc)
Andy Key
Err, thanks Andy!
kennyyeung
Version: 9.4 MRC
Excel Version: 2000
Thanks!
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
I have been trying to write a generic function using the APi to retrieve a cell value but am getting the same result as described above. Can anyone see what I have done wrong?
  • TM1CubeCellValueGet comes back with a very long number that I do not recognise;
    TM1ValType returns 6 which I believe is an error (TM1ValTypeError);
' Returns the current value for the specified cell.
' CubeName should be in the format "Server:CubeName".
' DENVP (Dimension element name/value pairs) E.g. "Dimension1", "Element form Dimension 1", "Dimension2", "Element form Dimension2"
Public Function GV(CubeName As String, ParamArray DENVP())
  Dim i As Integer
  Dim hElementArray() As Long
  Dim hCube As Long
  Dim hEACapsule As Long
  Dim h As Long
  Dim v As Long
  ReDim hElementArray((UBound(DENVP) + 1) / 2)
  For i = 0 To UBound(DENVP) Step 2
    h = TM1ObjectListHandleByNameGet(m_hPool, m_hServer, TM1ServerDimensions(), TM1ValString(m_hPool, DENVP(i), 100))
    v = TM1ObjectListHandleByNameGet(m_hPool, h, TM1DimensionElements(), TM1ValString(m_hPool, DENVP(i + 1), 100))
    hElementArray(i / 2 + 1) = v
  Next
  hCube = TM1ObjectListHandleByNameGet(m_hPool, m_hServer, TM1ServerCubes(), TM1ValString(m_hPool, CubeName, 100))
  hEACapsule = TM1ValArray(m_hPool, hElementArray(), (UBound(DENVP) + 1) / 2)
  For i = 1 To UBound(hElementArray)
     TM1ValArraySet hEACapsule, hElementArray(i), i
  Next
  Debug.Print TM1CubeCellValueGet(m_hPool, hCube, hEACapsule)
'  Debug.Print TM1ValType(m_hUser, TM1CubeCellValueGet(m_hPool, hCube, hEACapsule))
End Function
Mike Cowie
Version: Anything thru 11.x
Post by Mike Cowie »
Hi:
First, if you're doing this from VBA then why go to the trouble of using TM1CubeCellValueGet? Just call TM1's DBR function as noted below as it is much safer and easier in VBA - you're reinventing the wheel if you use TM1CubeCellValueGet from VBA.
If this is not in VBA where you must use TM1CubeCellValueGet to retrieve a value then you can not specify the server with the cube name or any dimension name - this is likely why it is failing to retrieve a value for you. The server:cube or server:dimension syntax is only relevant to TM1 Excel/VBA functions like DBR, DIMIX, etc. When using the TM1 API you have to remove any server prefixes since the API already knows what server a specified cube or dimension belongs to. Note you can use the TM1 Error functions to retrieve the exact error number and string, too (TM1ValErrorCode and TM1ValErrorString_VB).
Mike
Mike Cowie
QueBIT Consulting, LLC
AmbPin
Version: 9.5.2
Post by AmbPin »
Thanks Mike,
Actually I realized that I had actually only retrieved a handle for the value, not the value itself.
' Returns the current value for the specified cell as a variant.
' Parameters:-
'   CubeName: Name of the cube holding the required value.
'   DENVP:   (Dimension element name/value pairs) E.g. "Dimension1", "Element form Dimension 1", "Dimension2", "Element form Dimension2"
Public Function GetCellValue(CubeName As String, ParamArray DENVP()) As Variant
  Dim i As Integer
  Dim hCube As Long
  Dim hRetVal As Long
  Dim hRetValType As Long
  Dim sErrMsg As String * 100
  Dim ErrCode As Long
  Dim h As Long
  Dim v As Long
    h = TM1ObjectListHandleByNameGet(m_hPool, m_hServer, TM1ServerDimensions(), TM1ValString(m_hPool, DENVP(i), Len(DENVP(i))))
    v = TM1ObjectListHandleByNameGet(m_hPool, h, TM1DimensionElements(), TM1ValString(m_hPool, DENVP(i + 1), Len(DENVP(i + 1))))
  Next
  hCube = TM1ObjectListHandleByNameGet(m_hPool, m_hServer, TM1ServerCubes(), TM1ValString(m_hPool, CubeName, Len(CubeName)))
  Next
  hRetVal = TM1CubeCellValueGet(m_hPool, hCube, hEACapsule)
  hRetValType = TM1ValType(m_hUser, hRetVal)
  Select Case hRetValType
    Case TM1ValTypeError()
      ErrCode = TM1ValErrorCode(m_hUser, hRetVal)
      TM1ValErrorString_VB m_hUser, hRetVal, sErrMsg, 100
      Err.Raise ErrCode, "GetCellValue", "Cannot get the specified cell Value!" & vbCrLf & sErrMsg
    Case TM1ValTypeString
      TM1ValStringGet_VB m_hUser, hRetVal, sErrMsg, 100
      GetCellValue = sErrMsg
    Case TM1ValTypeReal
      GetCellValue = TM1ValRealGet(m_hUser, hRetVal)
  End Select
End Function
