TM1 'Set Dimension Order' Not Working
- Version: 10_2_2
Hi:
I am trying to set a dimension order manually however after rearranging the dimensions in dimension editor, selecting 'set dimension order' and then 'Dimension' 'Save' it will not preserve the order.
Each time I go in to look, the order of the elements reverts back to the original order before the reordering.
I am trying this in Perspectives, but have also tried in Performance Modeler using 'move up' and 'move down' but have the same result.
Has anyone else experienced this?
Many thanks,
Many thanks,
- Version: 9.5.2
- Excel Version: 2007-10
Re: TM1 'Set Dimension Order' Not Working
I think the order that you are seeing is the order in which elements were added to the dimension (The index) and therefore this will not generally be affected by you moving them around in the editor.
- Version: 10_2_2
Yes, I think so.
Is there no way to change this then?
It is for a time hierarchy - so my users are not happy to see July before June.
Many thanks for your assistance.
You can put the elements in any order you want if you do it through an XDI workbook.
- Version: 10_2_2
Many thanks for this.
I see that you can create dimensions using xdi/dimension worksheets, but can you create an xdi from an existing dimension if it was not originally built with one?
Kindest,
Kindest,
- jim wood
- Version: PA 2.0.7
Yes you can. I would read through how to create a dimension using an XDI. Keep in mind your local server setting etc. Especially if you want multiple people editing the dimension. Another option is to recreate it using a CSV and TI. If you set the order in the TI or even within your CSV you should be good. Hopefully this will then be a one off exercise.
Shop at Amazon
Shop at Amazon
- Version: 9.5.2
There are various sorting options available to you via MDX also if you wanted to create some dynamic subsets.
Right click on dimension and choose Export Dimension. This will create a CSV version of what the XDI would look like to create that exact same dimension. Open the file in Excel with Perspectives loaded, move the elements around to get the desired order, then save as an Excel workbook with the name "YourDimensionName,xdi". Don't forget the quotes around the name or otherwise you'll get a file name of YourDimensionName.xdi.xlsx. You can save the dimension on the server by choosing TM1, Developer, DImension Save.wigglyrat wrote:Many thanks for this.
Kindest,
FWIW, any time I have a smallish dimension that has to be in a specific order, that is not alpha sortable, then I use an XDI to ensure I get the dimension ordered exactly as I want it. As others have stated, you CAN accomplish this through TI but it's not nearly as easy if you have an already existing dimension.
- Version: 10_2_2
All very helpful, thank you for your replies.
- paulsimon
- Version: PA 2.0.5
I would also check the }DimensionProperties cube for that dimension to see if any Sort Order has been stored there.
- OLAP Product: Cognos TM1, EP, Analyst
- Excel Version: 2013
Is there a default subset created for this dimension? Is it possible that you were looking at the default subset order instead of the indexed order?
MK
- OLAP Product: Cognos TM1 Planning Analytics
- Version: 10.2.2, 11.0
- Excel Version: Excel 2019
I found this topic for the same issue, the button "Set Dimension Order" seams not to be working. It does, but you need to save changes to the structure of the dimension before.
Arrange your elements.
Press "Set Dimension Order" button
Save your changes
Then only re-open the dim editor and your elements indexes will be correct.
Save your changes
Thanks for posting. But isn't it normal behaviour that you save (or cancel) the changes you make - in this case dimension changes ?Xavier 13 wrote: ↑Thu Oct 04, 2018 10:21 am Hello,
Save your changes
If you don't save, TM1 will ask you anyway.
Well it's stupid but I was keeping the subsets editor open and was expecting to see the index changing in the details panel right away after I pressed the button.
