How to rename the security group?
Learn_TM1
Excel Version: Excel 2010
Post by Learn_TM1 »
I want to rename one security group. For example, change group AA to AB And I got to know that it is not able to rename one security group, instead, must delete this group AA, then add a new group AB. However, all client/group assignment will be lost for the old group AA. Is it one method to write a TI process to add a new group AB firstly, assign the same client/group to AB as AA, then delete group AA?
Learn_TM1
Re: How to rename the security group?
Yes, that's a good way to proceed, but only a part of the solution.
Note that security that is set manually (through the interface or straight into the }... security cubes), will likely be lost when deleting the (original) group.
So in between assigning users to the new group, and deleting the original group, you will need to get the security rights of the new group equal to those of the original group.
- For TM1 objects where security is done with rules and the rules automatically carry over to the new group: no problem
- For TM1 objects where no security was applied: no problem either
- In all other cases: you'll likely have some work to do
Consider if using an alias on the }Groups dimension could be a quick solution to your problem of renaming a security group.
qml
Excel Version: 2007 - 2016
Post by qml »
You could try using the SwapAliasWithPrincipalName method. I have never tried it on a control dimension, but there is a good chance it will work.
  • Create an alias (e.g. called NewName) on the }Groups dimension.
    Populate the alias with the new name for the group whose name you want to change.
    Execute SwapAliasWithPrincipalName( '}Groups', 'NewName', 0 ) in a TI.
    Remove the alias.
Needless to say, try it in a dev environment first as things could go wrong!
Kamil Arendt
qml wrote:You could try using the SwapAliasWithPrincipalName method. I have never tried it on a control dimension, but there is a good chance it will work.
    Remove the alias.
I will do the tests for a customer of mine, somewhere in February-March, because they move from Cognos Express 10.2.1 to Cognos Express 10.2.2.
After the work is done I will report back the findings but I expect SwapAliasWithPrincipalName to do a good job when migrating from CAM security to native TM1 security.
qml
Post by qml »
I have tried the SwapAliasWithPrincipalName on the }Groups dimension since my previous post and it worked perfectly. The version I tried it on was 10.2.2 FP4.
Kamil Arendt
True. I did the same test on the same version, same finding (of course).
dsproffitt
OLAP Product: All of them
Version: All of them
Excel Version: 2003 -2013
Post by dsproffitt »
Please bear in mind that SwapAliasWithPrincipalName is an unsupported function and as such, all data should be backed up before using it.
What you really should do, is export your data create a new dimension with the correct element names then rebuild your cube an reimport the data.
