TM1 Perspectives - Cannot view transaction log
winshent
Excel Version: O365
Post by winshent »
Hi guys
From TM1 perspectives I cannot open the transaction log filter screen when right clicking on an instance, or selecting from the Server menu.
The "View Transaction Log.." option is enabled via both methods..
Any idea how i can get this working ?
deepakjain2020
Version: 9.5.2; 10.2.2
Re: TM1 Perspectives - Cannot view transaction log
Post by deepakjain2020 »
Hi Winshent,
Are you getting any error message when you click on View Transaction Log?
What is happening when you are trying from Architect?
Deepak Jain
winshent
Excel Version: O365
Post by winshent »
Hi.. no error message, just nothing happens..
This is on my client machine btw... Architect is only on the server here.
winshent wrote:Hi.. no error message, just nothing happens..
Have you tried using [Windows Key] + [Left Arrow] after selecting the option in case the dialog is appearing somewhere off screen? (This may or may not be the cause, but notebooks which are regularly hooked into different monitors and different resolutions sometimes have a problem with the last "remembered" window location being somewhere way off screen. Windows + Arrow brings it in to the current location.) I don't think that the transaction log dialog remembers its last location, but it's worth a shot. (Also it assumes that you haven't disabled Areo Snap; disabling that disables those keys as well.)
Gabor
Version: [2.x ...] 11.x / PAL 2.1.13
Excel Version: Excel 2016-2021-365
Post by Gabor »
I can remember there was a msmask32.ocx issue in earlier versions from time to time. Sometimes it came back with an error and sometimes it simply did nothing, similar to what you describe now. I have seen that on client machines as well as on Server 2008, which is mentioned in attached Technote.
I even saw different versions on clients which should have the same setup, where copying this file from a working machine and re-register helped to get it to work again.
http://www-01.ibm.com/support/docview.w ... wg21469061
