Cube data extract with"semi colon" separted values
SBK88
Version: 9.5.2
Post by SBK88 »
Hi friends,
Need your help
I want to extract a cubes data into a csv file with the values being separated by "semi colon" instead of "commas".
Also to have column header too ( dimension name as heading for each column).
Ex.
Products;Countries;Value;
abc;sweden;10;
xyz;china;20;
I was trying ASCIIOutput and TextOutput Functions .
Suggest me some solution.
Thanks.
Re: Cube data extract with"semi colon" separted values
SBK88 wrote: I want to extract a cubes data into a csv file with the values being separated by "semi colon" instead of "commas".
In the Prolog, set the following value:
DatasourceASCIIDelimiter=';';
SBK88 wrote: Also to have column header too ( dimension name as heading for each column).
Ex.
abc;sweden;10;
xyz;china;20;
In the Prolog, enter the following:
lRow=0;
As the first line in the Data tab, enter the following:
lRow = lRow + 1;
After that, put an If() block in to write the column headers if, and only if, the row count is 1. Something like this:
# Print headings on first row only.
# Note the outputs are literal strings, not variables.
If (  lRow = 1);
    AsciiOutput( SC_FILENAME, 'V1', 'V2', 'V3', 'V4', 'V5', 'Value' );
EndIf;
After that, write the data using your normal AsciiOutput or TextOutput function, as the case may be.
SBK88
Version: 9.5.2
Post by SBK88 »
Thanks Alan,
I am having one more issue, all the values are coming in double quotes
ex. "abc";"40.40";
How to remove this double quotes from each values.
Have a look in the reference guide for DatasourceAsciiDelimiter and this should give you a link to other TurboIntegrator Local Variables and the one you need.
BR, George.
What George said. We keep a link to the most recent version of the Reference Guide in the FAQ since it's the single most useful piece of documentation there is, but for brevity the 10.2 one is here.
You should definitely browse through it periodically to keep up to date with the functions that are available to you.
SBK88 wrote:Hi friends,
Need your help
Ex.
abc;sweden;10;
xyz;china;20;
Thanks.
Hi sbk88,
I'm just wondering are you an end user an IT admin or a TM1 consultant?
