I'm trying to find out if there is a way to rename a TM1 service in the registry. I don't mean the displayed name in the services list, I've changed that already. I mean the actual service name which is displayed down the left hand pane in the registry editor. I tried just editing the name in the left hand pane and restarting the server but then the service does not start. (I changed it back to Planning Sample and it started fine so it's not a cfg file issue)
I know that I could install a new service and I know that I can even do that through running a DOS script (although I'd need to google the syntax!) but surely there must be away of amending it directly in the registry
Background:
Basically we wanted to run an additional tm1 service and I noticed that whenever the original install was done, someone had installed the default TM1 Planning Service and then subsequently installed another service which became the one they used. So rather than install a new service, I have simply amended the planning service by changing the display name and cfg path in the registry. It's now displayed as Tm1Dev however if someone wants to find it in the registry they have to remember to look for Planning Sample (i will document it of course!!
Thanks, advice is much appreciated!
