Hello all,
I have TM1 10.2.2 FP2 and trying to use windows performance monitor tool as described here: http://www-01.ibm.com/support/knowledge ... ml?lang=en
I'm stuck at "2. Select IBM Cognos TM1 from the Performance object list". There is no such object in my PerfMon. I also searched everything like "Cognos*", "TM1*' and even "Applix*"
Should I install something else to see the TM1 counters in windows PerfMon?
TM1 counters in Windows Performance Monitor
BrianL
- Version: 9.5.2 10.1 10.2 PA2
Re: TM1 counters in Windows Performance Monitor
Sounds like the tm1permondll.dll is not correctly registered.
Easiest way to correct is to open a command prompt as admin (explicitly right-click and select "Run as admin"). Then execute regsvr32.exe against tm1perfmondll.dll. It should look something like this:
Obviously, edit the paths as needed.
%systemroot%\System32\regsvr32.exe "C:\Program Files\IBM\Cognos\TM1\bin64\tm1perfmondll.dll"- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Hi BrianL, thanks for your reply,
I've tried this (also tried \SYSWOW\regsvr32.exe and bin\tm1perfmondll.dll: all the 4 combinations): nothing helped
BrianL
Did you have a previous version of TM1 installed? You can try running regsvr32.exe /u tm1perfmondll.dll first to explicitly unregister the dll if a different version had previously been registered.
You may also need to set a registry flag before registering will work.
Beyond that you may have to contact IBM support.
HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib\Configuration Flags = 0x10000Beyond that you may have to contact IBM support.
