Has anyone else experienced TM1Web causing increases in RAM usage?
Our IT guys have raised this as a possibility for our latest growth spurt on RAM...
I personally think it's more likely to be from the latest Plan/Forecast cycle but just want to double check.
NOTE that we have already increased the Memory per the below thread to 4GB (seems a little excessive to me for max. 5 users).
http://www.tm1forum.com/viewtopic.php?f ... web#p55981
RJ
TM1Web causing increase usage of RAM?
- OLAP Product: TM1 + BI
- Version: 10.2 10.2.2 + 10.2.1 10.2.2
- Excel Version: 2010 32 bit
Re: TM1Web causing increase usage of RAM?
Hi RJ!,
Do you have websheets in TM1Web? If yes, websheets do increase the RAM usage.
Any chance that it's this issue?RJ! wrote: Has anyone else experienced TM1Web causing increases in RAM usage?
Had not see that link, will get our IT Support to confirm the settings & update the thread.
FYI - We don't use Web sheets or active forms etc. TM1 Web has been used as a stop gap for our regional colleagues to use in a similar manner as Perspectives in that they can explore & "Snapshot/Slice" to excel.
