Feerders
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Feerders
Post by BariAbdul »
Hi Gurus,I am little bit confused about this IBM Tech note I came across ,According to it
The TM1 server then re-runs the feeder calculation process (as is done on initial server startup) so that any feeder changes made in the rule file are picked up, and any new feeders are created.
As for my understanding feeders with numeric data wouldn't change and retain the same values against the string feeders which are evaluated every time we save rules.
So,my question is given there are numeric feeders and old values changes to new values upon server start up,But does TM1 evaluates whole data points for numeric values that hasn't been changed. Thanks
http://www-01.ibm.com/support/docview.w ... wg21425310
Re: Feerders
BariAbdul wrote:But does TM1 evaluates whole data points for numeric values that hasn't been changed.
The link you provided is talking about what happens when a rule is changed. Whenever that happens TM1 has to re-evaluate ALL feeders because it doesn't know what you changed. There is no "shadow" copy of the rules somewhere that TM1 compares your new rule file against to see what has changed. Think about just how difficult that would be to program into the engine, for almost no benefit.
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Feerders
Post by BariAbdul »
Thanks Tomok.Appreciate your reply.
deepakjain2020
Version: 9.5.2; 10.2.2
Re: Feerders
Post by deepakjain2020 »
Hi Abdul,
Processing of feeders changed in TM1 10.2.2
http://www.infocat.co.uk/blog/2015/2/4/ ... tm1-10-2-2
Deepak Jain
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Feerders
Post by BariAbdul »
Thanks for the update,Deepak.
