update dimension
Moh
OLAP Product: Cognos
Version: 10.1.1
update dimension
Post by Moh »
Good afternoon Gentleman, I have a doubt ,I am destroying hierarchy and try to rebuilt again.Please see attachment.How to update the dimension after unwinding it.
Hierarchy.docx
(18.6 KiB) Downloaded 189 times
Re: update dimension
All I will say is that your code is doing as instructed. This is generally what code does.
Think through what the intended result is and the steps needed to get there and it should be obvious.
Moh
Version: 10.1.1
Post by Moh »
Thank you.I deleted attributes and write Dimensionelementinsert(dim,'','Apple','1');
#DimensionElementComponentAdd(DimName, ConsolidatedElName,ElName, ElWeight);
DimensionElementComponentAdd(DIM,'Total','Apple',1);
DimensionElementComponentAdd(DIM,'Total','Banana',1);
DimensionElementComponentAdd(DIM,'Apple','A',1);
DimensionElementComponentAdd(DIM,'Apple','B',1);
DimensionElementComponentAdd(DIM,'Banana','C',1);
DimensionElementComponentAdd(DIM,'Banana','D',1);
I am not getting the hierarchy as I want.I had started TM1 as junior then moved to Pentaho and moved back again to
TM1.
