TM1 process error :Cannot convert field 8
himanshurai420
Excel Version: 9
Post by himanshurai420 »
I am new to TM1 and trying to create a TM1 process to write data into .csv file from a cube view and for the same i m using asciioutput function.
Below is the function and the error message.
asciioutput('file.csv
',version
,category
,detail
,unit
,component
,numlist
,period
,numbertostring(value));
Error message:-
Data source line (1) error: data procedure line(0):cannot convert field number 8,value held for approval to a real number.
the above mentioned error is coming for all the records,
Could anyone of u please help me out.
thanks in advance.... :)
Re: TM1 process error :Cannot convert field 8
Hello
Did you check the variable type (numeric or string) for your 8th variable?
Please also note that AsciiOutput requires every argument to be a String (text instead of numeric).
Wim
himanshurai420
Excel Version: 9
Thanks Wim,
The variable type is string for field number 8.
thanks one again for ur information about Asciioutput function.
Please provide screenshots of the variable Preview, the variables tab, the code and the error message.
himanshurai420
Excel Version: 9
Sorry wim,
not able to provide the screenshot and the variable type is number of the field 8.
thanks...
Then set the variable type to String and if needed, use functions like StringToNumber, StringToNumberEx or Numbr to convert text to a number.
See: http://users.skynet.be/fa436118/wim/tm1 ... ngs_EN.htm
himanshurai420
Excel Version: 9
Thanks a lot Wim.....It worked :)
You're welcome !
