Unable to Change Table name in Query
tstagliano
Post by tstagliano »
We have a current TI process which pulls data from a 1 table with no issues. We are trying to point that query to a new table with the same fields that hold historical data, but when i change the FROM clause of the query to be the new table name, i receive the error message below.
"SQL Statement failed"
I am however successfully able to run that query directly on the SQL server with results.
Please advise.
jim wood
Version: PA 2.0.7
Re: Unable to Change Table name in Query
Post by jim wood »
What ID are you using in the ODBC connection? Does it have access to the table? when you ran the query successfully on the server did you login as you or the user named in your TI?
tstagliano
Thank you Jim. The service account we are using did not have access to that table.
jim wood
Version: PA 2.0.7
Post by jim wood »
It's a pleasure. I'm glad it's working.
