When we schedule a process to run as a chore, TM1 runs the chore as user 'R*AAAAA', 'AAAAA' is chore name.
Since we use TM1user() to get current user in the precess as part of export file name, the character '*' causes abnormal file name, and lead to fail of the process.
Is there any way for us to set the user to run chore? (or to remove '*' from user name), either for that chore, or for the whole server is OK.
Chris
How to set user to run Chore
- Version: 10.2
Re: How to set user to run Chore
An If statement would suffice.
If ( SubSt ( TM1User(), 1, 2 ) @= 'R*' );
sUserName = 'Automated Process';
Else;
sUserName = AttrS ( sDimClient, TM1User(), '}TM1_DefaultDisplayValue' );
EndIf;
- Version: 10.2
It's a good work around.
But it's the process being called uses TM1user(), I don't wish to change those processes. So I wish to set the user in the caller process.
Fortunately, I found tm1runTI can set user to call a process. Now comes a new problem, though I write the parameters same as the document specified, it always returns to me that the input paratemeters are wrong.
I have open another topic fo that.
Could somesome have a look for me, many thanks.
Chris
Chris
Or you can test if the user is in the }Clients dimension, if not then the user is a chore
Note if you are using CAM then the TM1_DefaultDisplayValue will be in the format Namespace/Full Name so if you want to use the user name as part of a string that will become a file name then you need to strip out illegal file name characters such as forward- and backslash. e.g.
Either way wherever the process is that is using the client name as part of a file name you are going to need to change the code there.
sUser = TM1User();
If( DimIx( '}Clients', sUser ) = 0 );
sUser = 'CHORE';
Else;
sUser = AttrS( '}Clients', sUser, '}TM1_DefaultDisplayValue' );
EndIf;
If( Scan( '/', sUser ) > 0 );
sUser = SubSt( Scan( '/', sUser )+1, Long( sUser ) );
EndIf;
- Version: 9.5.2 10.1 10.2 PA2
No, it's not possible to change the username a chore runs under.
As a work around, the chore could call a process using TM1RunTI.exe where you have to specify which user the process runs as. This does have some drawbacks, you won't be able to use multi-commit as TM1 won't think that it's a chore any more, just a process that has been kicked off by a user.
RHR
